> BOV
post Nov 19, 2003 - 12:15 AM
LBCxGUY
Joined Jul 6, '03
From Long Beach, CA..."LBC"
are they universal???
Replies (1 - 15)
post Nov 19, 2003 - 12:22 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (LBCxGUY @ Nov 18, 2003 - 9:15 PM)
so long as you have a turbo a BOV will work.
some are geared towards higher boost aplications and some are replacements for oem BOV's
but for the most part, yes, any BOV will work with any turbo car.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Nov 19, 2003 - 12:26 AM
LBCxGUY
Joined Jul 6, '03
kool thanks...i was just wondering thats all....just watched and listened to your clip and its just amazing....just thinking of lil things i can gather up first to start on a lil turbo project myself...well thanks!!!
post Nov 22, 2003 - 1:18 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
if your building boost on a budget look into a bosh BOV. there cheap and found it most vulvo's so they gotta work!! they also have a nicer metal one for a little more..
post Nov 22, 2003 - 12:17 PM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (zipstrips @ Nov 21, 2003 - 10:18 PM)
get a 1st gen dsm bov, those are metal
but then my bov was only $60 and i think it sounds and works pretty good
post Nov 24, 2003 - 1:54 AM
FAQdaWorld
Joined May 24, '03
From Milton, Delaware
Can a BOV be utilized for a supercharged setup? such as a 4agze? I know it allready has a ABV, but i'm wondering if u can change that to a BOV, cuz i love that PPPPPSSSSSSSSSHHHHHHHHHHTTTTTTTT sound!
-Ryan
AIM : FAQdaWorld
post Nov 24, 2003 - 2:13 AM
97sccelica
Joined Aug 30, '02
From Anaheim, CA
QUOTE (FAQdaWorld @ Nov 23, 2003 - 10:54 PM)
-Ryan
what does ABV stand for?
im pretty sure that it does the same thing as a BOV only it recirculates into the intake
post Nov 24, 2003 - 1:51 PM
FAQdaWorld
Joined May 24, '03
Yes, Air Bypass Valve...
I know thats what it does.... just wondering if i could use a BOV.. for perhaps other applications, like maybe eventually turboing it?
-Ryan
AIM : FAQdaWorld
post Nov 27, 2003 - 3:46 PM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
QUOTE (FAQdaWorld @ Nov 24, 2003 - 11:51 AM)
-Ryan
rolleyes.gif air bypass or blow off valve... same thing.. both bleed off pressure before it reaches the turbo.. different brands make different sounds.. and depending what sensor is on your car ie an AFM u cannot vent to astmophere.. it has to be recivculated.. and if the opening is inclosed to feed the o2 to the turbo inlet the sound will be muffled.
correct me if sensors or tech info is wrong..
post Nov 27, 2003 - 6:01 PM
Guest_Jason_*
Air Bypass Valve and a Blow off Valve work differently.
They aren't the same thing.
If you want to use a BOV on your Supercharged engine, save some money and get your engine Turbo'd too. It'd be intense to see a 6GC running SC Boost and TC Boost.
post Nov 27, 2003 - 7:55 PM
Jabberwock
Joined Sep 22, '03
What about ones like HKS SSQV and Blitz DD, they have different chambers and other technical stuff....
would they work well with AFMs?
post Nov 28, 2003 - 2:14 AM
boosted_K2
Joined Aug 30, '02
From Michigan
the difference is the springloaded aftermarket BOVs blow metered air off into the atmosphere, making the motor run rich. this is why stock, most applications use a ABV or BPV... these recirculate the air back into the intake, so you dont loose the air, and the motor wont run rich. SSQV is the only aftermarket BOV that im aware of to utilize a non-springloaded system, which has a twin chambered air system. this allows for quicker and more precise action, but with the 2nd staggered larger chamber, it allows for large ammounts of air to escape for large boost applications. the stock ones use the dual chamber setup, but it doesnt allow for large ammounts of air to escape
No but I don't buy it
Cause I'm...
post Nov 28, 2003 - 2:17 AM
From what i've heard the SSQ works pretty well with the AFM's.
post Nov 28, 2003 - 2:06 PM
FAQdaWorld
Joined May 24, '03
How could one twin charge the 4agze? Out of curiousity. I know it's an option but i'm wondering at how much more $$$$ its gonna cost to take the project that far. For now i am just gonna run the 4agze w/ the supercharger and HKS pulley (should be around 14psi), then we'll see what happens from there. Hopefully my swap will be done by spring break rolleyes.gif ....
What i'm asking is like how does the twincharging work? Does it have the SC'er working during one set of rpms? and the turbo kicking on after it reaches another set and turns of the super? wouldnt that cause boost spikes and such? I'm just curious on how it would really work............
-Ryan
AIM : FAQdaWorld
post Nov 30, 2003 - 8:45 AM
zipstrips
Joined Sep 9, '02
From Scranton, Pa
do a search for the twincharged mr2... they now named it mr6 i think... 1mz? v6..
post Nov 30, 2003 - 11:42 AM
Guest_Jason_*
Twincharging works sequentially, the SC will handle initial boost, the Turbo eventually takes over shutting down the SC once the boost pressure in the Turbo Manifold is equal to the total boost pressure (has nothing to do with RPMs). The SC cuts out and gets bypassed when the turbo spools up to maximum boost. The Turbo pretty much blows into the SC. This puts the two Chargers in sync, allowing the quick build-up of boost. When both Chargers together reach maximum set boost, a Bypass Valve is slowly opened around the SC allowing the Turbo to continually increase boost (although manifold is always showing the same boost). When the Turbo alone is pushing maximum boost, the HKS SC Controller, which is monitoring Turbo boost, shuts off the SC clutch and allows the Turbo to take care of all the boosting. HKS has a Twincharger Kit, and you don't even have to worry about Turbo lag anymore neither. tongue.gif
This post has been edited by Jason: Nov 30, 2003 - 11:43 AM
Lo-Fi Version Time is now: August 25th, 2026 - 3:32 AM
