> how do i clean this??, valve cover
post Jul 26, 2010 - 6:55 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
since im rebuilding my engine...and waiting on the parts, i was thinking of painting my valve cover...but for that i have to clean it 1st.
I've tried a lot of engine degreaser, carborator cleaner and other fluids in my garage...
my question is, can i use water? like take it to a self car wash and presure wash it with water and soap?
this is what it is right now...
so can i use water to clean this up or what?
if nothing, can i just paint over it?
what paint should i use!
thank you!
also if you guys can help/suggest something on this forum
http://www.6gc.net/forums/index.php?showtopic=74264
Replies (1 - 19)
post Jul 26, 2010 - 6:59 PM
NOVAKx17
Joined Oct 7, '09
ha well i definately wouldn't paint over it... get a good rough scrub brush and go to town on it with engine degreaser,
you put enough elblow grease into it i'm sure it will come off.. . mine did (:
and don't quote me on this but since its off your car i'm like 99% sure you can pressure wash it with
no problems, i mean they sandblast them all the time. i would just make sure that you dry it very well
and then clean it with degreaser again to get it chemicly clean before you paint it tongue.gif
NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold
1997 Celica ST- swapped and sold
2004 Ford explorer xlt 4x4- totaled
1997 Celica Convertible GT- Going Topless (;
(18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi
( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 )
post Jul 26, 2010 - 7:32 PM
rave2n
Joined May 29, '09
From Gainesville, FL
I'm pretty sure, as long as its dry after pressure washing, it'll be just fine. No water in the engine obviouslly.
This post has been edited by rave2n: Jul 26, 2010 - 7:32 PM
post Jul 26, 2010 - 9:10 PM
mgnt232
Joined Mar 16, '09
WOW! what in the world does your engine bay look like!? lol but good your cleaning it up smile.gif
I used soap and water and a couple SOS pads, and mine came clean.
I also was concerned about the water, so I taped and put a little bit of paper towel in the 4 plug holes. I wasnt sure if water would mess up the rubbery gaskets inside, so I would tape it off a little as a precaution.
And just scrub I dont think the car wash would help much just let it soak with degreaser, and scrub. Should come relatively clean smile.gif But keep in mind it wont come 100% clean easily.
And as far as paint, go to the auto parts store. and get whats called "engine enamel" (spray can) comes in all colors, if it cant come clean (assuming you want an OEM look) I would paint it a silver or black looks very clean smile.gif
Just make sure you tape off the "16 valve" thing if you paint, because it looks alot better than if you paint over it.
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Jul 27, 2010 - 1:33 AM
Let me ask you this: if you've already used a ton of chemicals on the valve cover, why would you be afraid of applying pure H2O? Grab a pressure washer and a good wire brush and work your elbow for a few hours.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Jul 27, 2010 - 8:53 AM
go to autozone and get a can of stuff called aircraft paint remover. its a very strong stripper. let it soak on the valve cover and then wash it of and use a brush. it will look brand spanking new. another option is take it to a shop and have it media blasted. they can use baking soda now and it will wash away.
post Jul 27, 2010 - 12:35 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
wire brush will clean it up nice. time consuming though...
My F/S Thread!
Ferdi says (11:29)
post Jul 29, 2010 - 4:36 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
WOW! Forget wire brush, you need a wire wheel!
post Jul 29, 2010 - 6:58 PM
wow found it, you owe me. after 30 mins
http://caswellplating.com/powder/s_stripper.html
QUOTE (jazzcornet @ May 6, 2008 - 9:00 PM) *
those "separators" are called oil baffles, and yes, they do serve a purpose. some valve covers have rivited oil baffles while some have bolts. the ones with bolts are easy to remove, but the rivited ones can not be removed without retapping the holes and using bolts afterwords. IF YOU HAVE RIVITED OIL BAFFLES, DO NOT SAND BLAST OR USE ANY TYPE OF SOLID CLEANING/ABRASIVE MEDIA WHATSOEVER!!! if even one little glass bead or piece of sand remains in the oil baffles, it could mean the end of your expensive motor.
if yo uhave rivited oil baffles (like the dirty valve cover ^^^) be sure to use only chemicals. the link to the stripper i gave in my last post works flawlessly and effortless. it's a little pricey, but well worth it, you may also want a soft metal wire brush to aid in cleaning it.
post Jul 29, 2010 - 7:57 PM
joehernandez
Joined Aug 5, '06
From San Luis AZ
man just get a degreser, some steel wool (the toughest one) and water, thats how i cleaned mine! look
post Jul 30, 2010 - 1:18 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
wow thanks for the help guys!!
well what if im planning to paint the cover afterwords??
post Jul 30, 2010 - 1:39 AM
JuMPiiN
Joined Nov 10, '09
From Louisiana
SOS Steel wool pads. I cleaned my entire engine bay with that and degreaser, I cleaned the valve cover, intake manifold, everything with steel wool pads. It took like 3 days but it was worth it.
post Jul 30, 2010 - 9:31 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Drill + wire wheel
**** Photobucket
post Jul 30, 2010 - 3:53 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
QUOTE (95CelicaST @ Jul 30, 2010 - 10:31 AM) *
Drill + wire wheel
Yeah, work smarter not harder!
post Jul 30, 2010 - 5:38 PM
blu94gt
Joined Mar 23, '05
From Kansas City
I've always had good luck with using an "oven-cleaner" product. Spray it on, let it soak and foam up for half an hour to an hour, then rinse it off. Typically everything will just wash off, if it doesn't then just do it again. I did that on my valve cover before painting it and it came out looking brand new.
1999 Celica GT
post Jul 30, 2010 - 5:45 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE (Spider77 @ Jul 30, 2010 - 1:53 PM) *
Drill + wire wheel
Smartest= blast cabinet
post Jul 30, 2010 - 5:50 PM
95CelicaST
Joined Feb 5, '05
Incorrect. Please reread the thread, with emphasis on njccmd2002's post.
**** Photobucket
post Jul 30, 2010 - 5:54 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Wouldnt want media hanging around the baffles.
post Jul 30, 2010 - 11:02 PM
youngboy815
Joined Jul 20, '10
From US
post Jul 31, 2010 - 2:06 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
QUOTE (95CelicaST @ Jul 30, 2010 - 3:50 PM) *
You'd only be blasting the outside. Mask off the rest. If you're really worried then get it soda blasted. It takes a little longer and is slightly more expensive but any soda left on the cover will rinse right off.
It's done all the time, just have to know what you are doing.
Lo-Fi Version Time is now: August 31st, 2026 - 10:37 PM
