> 3SGTE clutch with a 5SFE
post Aug 14, 2010 - 12:24 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
Can I use the whole 3sgte clutch kit with the 5SFE Transmission? I think I remember reading somewhere it could, but now I can't find it...
Kevin
Replies (1 - 11)
post Aug 14, 2010 - 1:06 PM
QUOTE (Soulend @ Aug 14, 2010 - 1:24 PM) *
Kevin
no.
you will need a 3s flywheel and pressure plate, and 5s clutch disk.
most of the companies will make you a custom 3s disk with 5s spline if you call them.
post Sep 8, 2010 - 1:24 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
which company do you suggest getting the costume Clutch kit from?
post Sep 8, 2010 - 2:01 PM
www.dxdracingclutches.com will make this clutch for you. ask for Andy in the imports dept.
post Sep 8, 2010 - 2:18 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
can a flywheel and pressure plate from a 2gen work on the 3gen
I only want to be faster than the guy next to me.
post Sep 8, 2010 - 2:29 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (Soulend @ Sep 8, 2010 - 1:24 PM) *
Buy ACT and forget about it. I abuse the pi$$ out of mine and the countless others I've owned in my life - doesn't give a fcuk about it biggrin.gif
QUOTE (99celiGT @ Sep 8, 2010 - 2:18 PM) *
Yes
This post has been edited by DEATH: Sep 8, 2010 - 2:30 PM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Sep 14, 2010 - 6:13 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
out of curiosity, why cant a 3sgte clutch disk work in the 5s? it seemed to fit fine.
kevin
post Sep 14, 2010 - 6:39 PM
the splines of the input shaft on the transmission are slightly different.
post Sep 14, 2010 - 10:48 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
has anybody bougt a clutch set from Spec clutchs, they have an application for this exact swap and was wondering if the company makes quality parts
post Sep 15, 2010 - 4:40 PM
spec disks tend to spit the springs out of them, i've seen 2 cases first hand, and heard about lots of others.
post Sep 15, 2010 - 8:30 PM
99celiGT
Joined Jun 23, '10
From Pawtucket, RI
well dam thats a pretty bad horror story, thanks for the info. I was pretty close to buying a set from them
post Sep 17, 2010 - 9:10 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (99celiGT @ Sep 15, 2010 - 9:30 PM) *
I had a spec stage three on my 2nd gen 3sgte with stock GT tranny. worked awesome. But i only ran this for maybe 3k tops before parting with the car, so i couldnt tell you if how it was in the long term. But for those 3k it was awesome.
Lo-Fi Version Time is now: September 1st, 2026 - 2:47 AM
