Nov 23, 2003 - 4:59 AM
What you can do is get two SPDT automotive relays, and then wire them up as follows.
Relay 1 85 - Wire that gives +12v when parking lights are on 86 - Ground 30 - Fused +12v from battery 87 - Illumination wires of gauges Relay 2 85 - Wire that gives +12v when ignition is on 86 - Ground 30 - Fused +12v from battery 87 - +12v wires of gauges Then you'd simply hook up the sensor wires to the sensors, and hook up the ground wires of the gauges to a good ground source. Then your gauges should work. -------------------- New Toyota project coming soon...
Nov 23, 2003 - 12:00 PM
Run the wires to your Illumination wire off your deck. Its yellow. They'll turn on when u turn your lights on.
This post has been edited by Supersprynt: Nov 23, 2003 - 12:00 PM -------------------- |
| Lo-Fi Version | Time is now: September 4th, 2026 - 2:43 PM |
