Sep 8, 2010 - 9:17 AM
![]() Enthusiast ![]() Joined Apr 16, '09 From Italy Currently Offline Reputation: 3 (100%) |
Here some picture of my last mod.
I totally removed the key to make the car start with a switch and a button. ![]() ![]() ![]() ![]() http://www.youtube.com/watch?v=YjjtaoLIz5g In this short video there is how it work and some note to explain what is and how it's made. The hole is still to cover, i have to find something that fits good. For any question write here or PM me. Probably soon I'll do a little kit with everything to install it you own, with a little manual too...PM me if interested... |
Sep 8, 2010 - 9:30 AM
Enthusiast ![]() ![]() ![]() Joined Mar 22, '07 From Murphy, TX Currently Offline Reputation: 5 (100%) |
Nice - hope to be able to do this down the road
Sep 8, 2010 - 12:32 PM
Sep 8, 2010 - 3:10 PM
I'd definitely be interested if the engine start button wasn't situated where the cigarette lighter used to be. I sometimes use that to charge my phone.
-------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Sep 8, 2010 - 3:36 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
this would make it much cleaner
This post has been edited by Johnnyny: Sep 8, 2010 - 3:37 PM |
Sep 8, 2010 - 4:57 PM
I'd definitely be interested if the engine start button wasn't situated where the cigarette lighter used to be. I sometimes use that to charge my phone. The button can be situated where you want, that's the easiest thing... this would make it much cleaner ![]() thanks for posting it, i used the one i already had and wanting to change it as soon as possible 'cause i dont like how it look...but when the wiring is done change it is really easy...everything is plug with fast-on... |
Sep 8, 2010 - 7:58 PM
so how do you use the accessories?..
Sep 14, 2010 - 5:55 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 20, '06 From Florida Currently Offline Reputation: 44 (100%) |
I have wanted to do this for a while, but if someone get's into your car, all they have to do is hit the switch and the button to steal it?
Sep 14, 2010 - 8:21 AM
Enthusiast ![]() ![]() ![]() Joined Jul 10, '08 From Tampa, FL Currently Offline Reputation: 8 (100%) |
That's actually pretty cool. How hard was it to do?
Also, I tend to agree with jcbass7 that it makes your car easy to steal. On the other hand if you conceal the accessory on/off switch it might not be too bad. I would be definitely interested in "how-to" article. This post has been edited by conus00: Sep 14, 2010 - 8:22 AM -------------------- '94 ST |
Sep 14, 2010 - 9:29 PM
That's actually pretty cool. How hard was it to do? Also, I tend to agree with jcbass7 that it makes your car easy to steal. On the other hand if you conceal the accessory on/off switch it might not be too bad. I would be definitely interested in "how-to" article. I think if I did this I would have a second fuel pump kill switch hidden somewhere. Maybe even some more random cut off switches. Activating more of them depending on where I park. Who knows. Whats that TRD button go for? expensive I'm guessing.. |
Sep 15, 2010 - 3:34 AM
round 160 i believe
Sep 15, 2010 - 8:26 AM
Enthusiast ![]() ![]() Joined Jan 16, '09 From Cyprus Currently Offline Reputation: 10 (100%) |
round 160 i believe They are so many and cheap start buttons into the e-bay so i don't thing somebody need to spend so much money for TRD button.... cheers -------------------- ![]() |
Sep 15, 2010 - 5:57 PM
This kit make harder to steal the car...hidding the main switch will be the first step, then it's easy to put "somewhere" for from the steering wheel a wire with a fast-on to by-pass the main switch...i did it on mine, and it's really hard to understand how to start the car...
To put everything on and make the sistem to work i took 3-4 hours, mainly to understand what the wires were for... Anyways, more info will be posted soon |
Sep 19, 2010 - 11:32 AM
The kit is almost done, it will cost beetween 80 and 60€, it's semi-plug'n'play.
With the product will come 3 relais (no cheap ones, probably bosh ones), wiring already done, the start button and the switch. The only thing you have to do is unplug the fast-on from the OEM key cylinder and connect it to fast-on on cables to relais. There will be instruction with the package. |
Oct 8, 2010 - 9:54 AM
Enthusiast ![]() Joined Feb 2, '10 From nowra, nsw, australia Currently Offline Reputation: 0 (0%) |
i got a viper alarm system installed into my car, so i can 'remote' keyless start. its the most awesome alarm. i can be inside my house, turn my car on and have the heater settings on, walk out to my car, unlock it, hop in to a nice cosy car. its also awesome to trick ppl when they see the car turn on and no one is in it
Nov 13, 2010 - 2:20 PM
Enthusiast Joined Nov 13, '10 From jacksonville,fl Currently Offline Reputation: 0 (0%) |
Hi, I was wondering if some one could help me reverse back to key-start ignition lock, i bought this car 1994 celica 1.8l lil over a year ago with push start already installed i know I need to get the original lock cylinder and housing but I think that I found out how to get the clock cylinder but don't have a clue when it comes to the housing, any help is much appreciated, thank you
| Lo-Fi Version | Time is now: September 14th, 2026 - 3:49 AM |
