Sep 29, 2010 - 3:01 PM
Enthusiast ![]() Joined Dec 9, '05 From Germany Currently Offline Reputation: 0 (0%) |
After dropping the idea of using ST205 calipers on a McPherson suspension i searched for radial-mount calipers and found some from Porsche that where perfect, they come from a 996 Turbo/GT3.
I use them with stock Toyota brake discs for the ST205. ![]() ![]() ![]()
Sep 29, 2010 - 3:04 PM
those look amazingg on there! IMO it would look better without the Porsche lettering on there.
How much did it cost if you don't mind me asking? |
Sep 29, 2010 - 3:17 PM
Calipers (used) 480€, caliper brackets (custom made) 240€, discs 200€ .. together about 920€ or 1250$
Not cheap but i won't regret it when i'm on the track |
Sep 29, 2010 - 3:18 PM
No, that's not cheap at all! lol but it's well worth it!
Sep 29, 2010 - 6:23 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
nice! how did you get abs on your celica???
-------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
Sep 29, 2010 - 7:38 PM
the ABS sensor doesn't connect to the caliper, it connects near the knuckle or some where around there so the change in calipers wouldnt make a difference.
Sep 29, 2010 - 9:56 PM
no you dont get it. he has a 1994 celica st. And If Im not mistaken I thought ST Celica's did not come with the option for ABS, it comes stock with drum brakes in the rear!!
Sep 29, 2010 - 10:05 PM
oh sh!t hahaa
but you wouldn't need ABS to put those calipers on it would you? |
Sep 29, 2010 - 10:09 PM
ABS or not doesn't matter. you can still use the caliper. ABS matters for Master Cylinder
Sep 29, 2010 - 10:22 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
just one question. Did you have troubles bleeding the brakes since the bleeder is on the lowest point of the caliper?
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Sep 29, 2010 - 10:39 PM
Your calipers are on the wrong side.....The bleed screws are at the TOP.
![]() I like what you did with the PCAR brakes.....just need to get the put on correctly... |
Sep 30, 2010 - 12:52 AM
Enthusiast ![]() ![]() ![]() Joined Jan 16, '07 From covington, KY Currently Offline Reputation: 9 (77%) |
Sep 30, 2010 - 4:03 AM
All Celicas in Germany got ABS and disc brakes in the rear, even the ST
We had to put the calipers with the bleed screws this way, on the 996 Porsche the calipers are on the other side of the steering knuckle and they got 2 different pistons sizes. There's only one direction you can install calipers like that without sacrificing some performance. On my first pic you can see that the left piston is smaller then the right one, the brake disc should always first pass the smaller piston and then the bigger for best performance and wear. It's not easy to bleed them now but... how often do i have to bleed my calipers.. Maybe i will just swap the screws and the brake line, but i will have to get a custom line made for this. This post has been edited by Hafkai: Sep 30, 2010 - 4:13 AM |
Sep 30, 2010 - 5:33 AM
Maybe you should email Porsche and tell them they are doing it wrong then...
Probably should just mount the right caliper on the right instead.... |
Sep 30, 2010 - 6:04 AM
Porsche does nothing wrong
![]() The calipers are one the right sides on my car, they're just supposed to be mounted on the other side of the steering knuckel where the steering arms are on our cars. If i would put the left caliper on the right side and the right caliper on the left the whole thing with the different sized pistons would be counterproductive |
Sep 30, 2010 - 8:58 AM
great work, sadly is not a cost efficient option for most, but great work on your part.
remove the porsche letters and it'll look a lot better. and the calipers are on the right side, but due to bolting point they are rotated ~ 90 degrees forward, I saw that right away lol, maybe I've been looking at too many brake systems. about the bleeding point, I'd leave them like that, bleeding them I'm sure is tough but not impossible and you don't have to do it once a week anyways. -------------------- ![]() |
Sep 30, 2010 - 11:18 AM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
Props to you man, don't remove the logo.
-------------------- ![]() I will return one day. |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 1:05 AM |
