> ST drums to GT discs, Who's done it? I have a question
post Jan 9, 2011 - 6:16 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I was talking to a brake guy about doing it, and he said that I'd have to do all this extra stuff that wasn't in the how-to to make it work. Like I'd have to get a brake booster from a GT, etc. Basically the whole GT braking system. So my question is, to my fellow ST guys, after installing the GT rear discs, has everything been well? Brakes performing perfectly? Because I'm going to do it in the near future.
June '12 COTM
'95 AT200
Replies (1 - 23)
post Jan 10, 2011 - 1:06 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
We don't drive hOndas, brake master is the same amongst the st and gt. Brake bias might change but only by a minute amount. Now by replacing the st front brakes with a gt setup bias will be the same as a gt.
94 Celica gt white (sold)
post Jan 10, 2011 - 12:49 PM
Johnnyny
Joined Apr 28, '09
From York pa
same as GT4 also
post Jan 10, 2011 - 2:45 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
basically use the rear hubs and ebrake lines and swap them out for the st stuff
2001 Solar yellow Lexus IS300
post Jan 10, 2011 - 2:55 PM
HectortheRican
Joined Dec 26, '09
QUOTE (96stgreendemon @ Jan 10, 2011 - 1:45 PM) *
I know that man. I know what to do, I've read the how-to several times. My question is if anyone has had any problems with braking performance or e-brake reliability. Things like that.
June '12 COTM
'95 AT200
post Jan 10, 2011 - 8:46 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
What you HAVE TO HAVE:
Caliper
Rotor
backing plate
ebrake hardware
GT brake lines
What you COULD have to make your life nicer:
Gt ebrake cable(don't attempt to call me on this one as ive been running a moded ST cable for 6 months now)
GT proportioning valve
Ive been running GT front and rear brakes for a good 6 months now and i have to say it is an AWESOME mod. I did get the whole system for crazy cheap but i notice a BIG difference in the braking power, and i'm not sure if its the rear disks or the fronts.(i do have to say the front GT caliper looks like it could eat the ST caliper, as well as the rotor having a slightly larger diameter.)
This post has been edited by SupraKid: Jan 10, 2011 - 8:50 PM
post Jan 10, 2011 - 10:05 PM
DEATH
Joined Dec 19, '07
From tx
If you wanna be thorough about it - change the proportioning valve like Suprakid said.
Other than that the systems are the same.
If you REALLY wanna do it right - change the front calipers and rotors to GT
This post has been edited by DEATH: Jan 11, 2011 - 8:43 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 11, 2011 - 12:00 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Does anyone know any cheap places to buy proportioning valves?
post Jan 11, 2011 - 2:31 AM
HectortheRican
Joined Dec 26, '09
QUOTE (Euphoria @ Jan 10, 2011 - 11:00 PM) *
Same
And I guess I'll do all four then! I'll do it in the summer when I actually have money.
June '12 COTM
'95 AT200
post Jan 11, 2011 - 8:45 AM
DEATH
Joined Dec 19, '07
From tx
It'll work fine and be improved in the meantime. I'd check the parts houses [O'reilley's, Autozone etc] for a reman'd first. You might be surprised how cheap they are.
Otherwise - I have a full set of GT Brakes in my garage. Contact Ngofcukinway for pricing info.
EXT: WRC/TRD/404
post Jan 11, 2011 - 11:12 AM
HectortheRican
Joined Dec 26, '09
QUOTE (DEATH @ Jan 11, 2011 - 7:45 AM) *
Hopefully they're there in the summer because I don't wanna buy anything ahead of time just in case if I need the money since I'm away from home with no job since I'm going to school full time.
June '12 COTM
'95 AT200
post Jan 11, 2011 - 10:41 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
if your short on cash just get a nice set of hawk hps brake pads for the front. Made braking for me quite better
2nd Gen 3s-gte.... It lives!
97celiman
post Jan 12, 2011 - 1:24 AM
HectortheRican
Joined Dec 26, '09
Can someone show me a comparison between the ST front rotor and caliper vs the GT front rotor and caliper?
June '12 COTM
'95 AT200
post Jan 14, 2011 - 11:10 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (HectortheRican @ Jan 11, 2011 - 10:12 AM) *
No reason to think they wouldn't be - they've been there for a year now laugh.gif
EXT: WRC/TRD/404
post Jan 15, 2011 - 2:55 AM
SupraKid
Joined Aug 15, '10
From The Best Coast
QUOTE (HectortheRican @ Jan 11, 2011 - 10:24 PM) *
Om nom nom nom little st caliper
The gt rotor is roughly 1" bigger in radius. And a tiny bit wider,maybe a 1/8". (this picture is with the ST rotor sitting on the studs backwards to compare diameter)
This post has been edited by SupraKid: Jan 16, 2011 - 12:25 AM
post Jan 30, 2011 - 10:53 PM
96stgreendemon
Joined Oct 7, '09
Bump on this since i really dont want to start another thread, Where exactly is the proportioning valve at? and what does it do?
post Jan 30, 2011 - 11:28 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
IIRC its attached to the master cylinder, id have to go look. It gives a certain % amount of pressure to the front/rear...On the ST the pressure in the rear is less than on the GT.
Just as a heads up tonight i got into a bit of a situation and the GT brakes saved my front end, im positive my ST brakes would not have(as ive had an accident) :\..
post Jan 30, 2011 - 11:46 PM
richee3
Joined Jun 29, '08
From Denver
No spilt Coke this time, Andrew?
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 30, 2011 - 11:52 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
No, more of a "holy **** how did my car just do that..."
post Jan 31, 2011 - 7:10 PM
samir0189
Joined Mar 8, '08
From Orlando, Florida
QUOTE (SupraKid @ Jan 30, 2011 - 11:28 PM) *
its on the firewall. Right side of this pic.
pic courtesy of Manny...
My F/S Thread!
Ferdi says (11:29)
post Feb 25, 2011 - 1:12 AM
mt953
Joined Sep 29, '10
From nebraska
so you can use the st e- brake cables on the gt rear disc swap?
and the front swap is just rotors and fully loaded calipers?
post Feb 25, 2011 - 9:25 AM
96stgreendemon
Joined Oct 7, '09
if you use the ST parking brake it will basically be wrigged up, use the gt cable, i thought i could use the St cable and it cost me a few extra hours
post Feb 25, 2011 - 7:11 PM
mt953
Joined Sep 29, '10
From nebraska
dose any one know the casting nubers for the gt front and rear calipers?
post Feb 25, 2011 - 8:49 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
I used the ST cables only because the car i got the parts off of was impossible to jack up to get the cables. And i can hear the brake pads making noise once and a while because of it.
Lo-Fi Version Time is now: August 23rd, 2026 - 4:26 AM
