> Water moving around in engine?, 3rd gen 3SGTE
post Jan 30, 2011 - 3:37 PM
nammer
Joined Aug 22, '07
From Burnaby, British Columbia, Canada
I was wondering if anyone could help me with this. I have a JDM GT-four and drive on the right hand side. Sometimes while driving I hear a sound like water swooshing around in the engine, towards the passenger side of the car (left hand side). At first I thought it could be the W2A intercooler...but it's topped off..and any water movement won't make that loud of a sound...then I thought i was crazy (lol) but other ppl hear it too haha..
It just sounds like water moving in a mostly empty reservoir...
Replies (1 - 15)
post Jan 30, 2011 - 3:51 PM
windshield washer tank?
post Jan 30, 2011 - 4:09 PM
pipes
Joined Apr 23, '08
From boston MA
you may need to bleed your system if air is in the heater core you will hear sloshing sound....turn the climate control to hot take the cap off an try to get it to burp and add coolant
post Jan 30, 2011 - 4:34 PM
you are low on coolant or you have air in the system. its water rushing into the heater core
post Jan 30, 2011 - 4:37 PM
mkernz22
Joined May 10, '10
From MA
heyyy, this is good help for me. i've noticed that sound for a while and never really thought of it
post Jan 30, 2011 - 5:53 PM
nammer
Joined Aug 22, '07
QUOTE (presure2 @ Jan 30, 2011 - 12:51 PM) *
no the sound is there even when the tank is topped
QUOTE (pipes @ Jan 30, 2011 - 1:09 PM) *
sounds good. I will try this!
QUOTE (Smaay @ Jan 30, 2011 - 1:34 PM) *
Thanks!
post Jan 30, 2011 - 7:30 PM
I need to do this as well, need to burp my baby
post Jan 30, 2011 - 7:38 PM
mkernz22
Joined May 10, '10
From MA
is it bad that there is an air bubble in them?
post Jan 30, 2011 - 7:47 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Thats one more area coolant could be to help cool the engine..
post Jan 31, 2011 - 2:58 AM
nammer
Joined Aug 22, '07
so to drain the W2A intercooler..there's a cream colored plastic thing near the foglights on the drivers side of the car (right side) that needs to be unscrewed...
where is the plug to drain the radiator? should i do this also while I'm at it?
toyota red for life coolant for both? how many liters?
post Feb 1, 2011 - 2:43 AM
nammer
Joined Aug 22, '07
post Feb 1, 2011 - 8:31 AM
lol quit asking things at 3AM.
the radiator drain plug is located typically near the bottom of the radiator. on my corolla it was on the drivers side and, sticking in towards the engine from the plastic side tank. On my Celica (7th gen) it's in a similar spot, my Mazda is also in a similar spot. If it won't open then just take off the lower radiator hose at the radiator.
post Feb 1, 2011 - 6:14 PM
nammer
Joined Aug 22, '07
haha it was 11:43PM for me when i posted smile.gif
Thanks! I will look into it
This post has been edited by nammer: Feb 1, 2011 - 6:14 PM
post Feb 14, 2011 - 10:07 AM
bsamps4
Joined May 16, '10
From Raleigh
That is so weird. I've been hearing the same thing in my car too. It's only when I start accelerating from a stop. I guess I'll go bleed again. I just finished putting a Koyo in the car.
post Aug 4, 2011 - 6:54 PM
ptownroro
Joined Oct 10, '06
From Portland, OR
Had the same problem with some occasional high temp problems. Burped and now everything is back to normal and no wooshing sounds. Thanks guys!
Augusto
post Aug 4, 2011 - 7:35 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
mines been doin sht like this forever, spits its coolant out the overflow and overheats,...
going to have a custom swirlpot and high mounted header tank made and if that doesnt fix it, ill simply inject my cooling system with a regulated 1.2bar feed from my ice tank into my thermostat housing and call it a day, ...
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: September 8th, 2026 - 4:06 AM
