> Shift Light, Flashing Guages
post Dec 2, 2003 - 10:39 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Just wanted to know what everyone thought about this idea and if it had ever been done. I have blue bulbs in there now and want them to flash at a set RPM or flash between two different colors like red and blue. Any thoughts? I think it'd be pretty cool cause I've never seen it done before.
Replies (1 - 11)
post Dec 4, 2003 - 3:13 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
So... I guess this is a bad idea.
post Dec 4, 2003 - 3:23 PM
Well, the gauge cluster could me made to flash, by splicing into your harness(es) and using a couple SPDT relays. You'd also need something to sent +12 volts to a relay once the specific voltage has been reached on your RPM signal wire, so you'd probably need to take apart a shift light or something for this, but I'm not sure.
It's gonna be very difficult, and flashing between two colors would be even more difficult.
post Dec 4, 2003 - 4:01 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
yeah I can figure out the wiring, just wondering if anyone thought it'd be a good idea or if anyone had done it before. Thanks for the input.
post Dec 4, 2003 - 7:17 PM
slipgun
Joined Jun 2, '03
From Annandale VA
sounds really cool to the is it a good idea, However doesnt seem as if it would be as affective as a single light turning on
post Dec 4, 2003 - 10:31 PM
aaronc222
Joined Sep 22, '02
From Detroit
I'll probably be doing something similar(probably a blinking LED placed in my field of view) once I get a better job and have more money to spend on the car again. I already have an Apexi Rev/Speed Meter, which has 2 aux outputs for specified RPM or speed engagement. I just need to find a good spot to mount the RSM now that I've switched radios. It used to sit in place using the radio to wedge it in place, but now I can't do that so I have to make a mount somewhere.
Let us know how it turns out.
post Dec 5, 2003 - 9:30 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
doGGy has just a shift light in his car...i dont know how its wired or anything, but i thought this might be of interest to you guys. Im wondering how you would set something like that to light up at the correct RPMS without the whole extra tach. confused.gif
EDIT- nevermind, i thought doGGy took a shift light off an aftermarket tach, but upon some additional research on my own i realized that they sell just shift lights. wink.gif
This post has been edited by Silver94CelicaOwner: Dec 5, 2003 - 3:47 PM
post Dec 11, 2003 - 12:46 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
QUOTE (slipgun @ Dec 4, 2003 - 6:17 PM)
i just figured that since the gauge cluster is so much bigger that it flashing would get your attention better than a small little light. I might try this on my thunderbird turbocoupe to see how it turns out. just don't wanna mess up the Celi. Thanks again for all the input. Later.
post Dec 11, 2003 - 1:15 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
if you have every driven a car with a good shift light you notice it.. doesnt really matter where you put it as long as its somewhere in your field of vision.. expessially at night wink.gif
I though about putting my shiftlight into the side airvent the left of the steering wheel where there is that little round indentation.. but not I am thinkin about makin a fiberglass piece to put guages in there.
99 project version 3.0.. hello SEMA 2010 =)
post Dec 11, 2003 - 1:21 PM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
That's just it most of my cars have been auto except for the turbocoupe I have now and the 3 speed 67 chevy my dad taught me to drive in. I say go for the idea with the guages.
This post has been edited by WannabeGT4: Dec 11, 2003 - 1:22 PM
post Dec 11, 2003 - 9:11 PM
QUOTE (aaronc222 @ Dec 4, 2003 - 11:31 PM)
I did the EXACT same thing with my RSM...but if u go over a bump it falls out.
post Dec 16, 2003 - 8:44 AM
blkGT
Joined Jun 10, '03
From FL
Ive seent his done. In my friends for escort. He changed the bulb colors of the shift lights from green to blue because it has no tach.
Lo-Fi Version Time is now: June 24th, 2026 - 6:13 AM
