Mar 13, 2011 - 2:09 AM
Enthusiast ![]() ![]() ![]() Joined Jan 30, '11 From Albany, NY Currently Offline Reputation: 4 (100%) |
So I was driving from work just now and noticed that while driving my break light will come on. It doesn't matter if I am shifting, cruising, or stopped. The break is not stuck or anything, any ideas of what could be causing this?
-------------------- ![]() Power in Balance 90 ST coupe- Sold 95 ST hatch- Dead :’( 02 Impreza RS- DD |
Mar 13, 2011 - 4:26 AM
Enthusiast ![]() ![]() Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
if you mean brake light as in emergency brake light.
check your brake fluid, you might be low. -------------------- ![]() |
Mar 13, 2011 - 9:29 AM
if you mean brake light as in emergency brake light. check your brake fluid, you might be low. The emergency brake doesn't have any fluid... Which brake light are you talking about though? Emergency brake or you're tail light? This post has been edited by mkernz22: Mar 13, 2011 - 9:29 AM |
Mar 13, 2011 - 12:03 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
Sometimes when it flickers on and off its brake fluid. I heard it could mean brake pads are worn down
Mar 13, 2011 - 6:07 PM
Yea it was the break fluid...all good now =p
Mar 13, 2011 - 10:40 PM
check your pads. brake level gets low cause pads are wearing out
Mar 14, 2011 - 12:27 AM
Will do =p
Mar 20, 2011 - 11:13 PM
if you mean brake light as in emergency brake light. check your brake fluid, you might be low. The emergency brake doesn't have any fluid... ps. you call the handbrake an emergency brake? i guess sometimes hairpin bends are emergencies -------------------- Mike W
| Lo-Fi Version | Time is now: August 29th, 2026 - 8:56 AM |
