> GENIII 3SGTE Part Number Thread gen3 3sgte, and where to get them
post Apr 2, 2011 - 6:34 PM
hey guys, figured we dont have a Gen III 3sgte part # thread here for quick refrence, so I guess its about time we do. lol
These all came from mr2oc, i just cleaned them up and made a list of them.
feel free to add as you guys want.
In case you dont know, you can look up part #'s for almost any toyota @ toyodiy.com, but US users cant see the diagrams that go with them, which can make them hard to decipher at times.
so, on with the list!
  • Water Pump Assembly 16100-79236 (You can use the Gen 2 water pump in the Gen 3 housing)
  • Oil Pump Assembly 15100-88460
  • Engine Overhaul Kit 04111-74541 (This is the Complete Rebuild Kit)
  • Hose from Hell, Water By-Pass #5 16282-88480
  • Hose, Water By-Pass #4 16281-88461
  • Head Gasket Kit 04112-74521
  • O2 Sensor 89465-29805
  • Distributor cap 19101-88364
  • Spark Plug wires 90919-21581
  • Rotor 19102-74040 (Same as 5sfe)
  • Belt, Timing 13568-79315
  • Tensioner, Timing Belt 13540-88480
  • Map Sensor: 89420-17050
  • Air Temp Sensor: 89424-12010
  • Thermostat 90916-03117 (Landcruiser pt#)
  • Valve Cover Gasket, Main(There are 2 parts) 11213-88480
  • Valve Cover Gasket, Inner 11214-88480
  • PCV Valve (Same as newer Camrys)PCV-301
  • Exhaust Manifold to Head Gasket 17173-88480
  • Oil Pipe Joint Gasket 15526-88480 ( You will need two of these to go on the large banjo type fitting.)
  • Oil Pipe Outlet Gasket 15472-88480
  • Intake Manifold Gasket 17177-88460
  • Exhaust Manifold Gasket 17173-88480
things like the rear main seal, and cam seals are the same as the gen2.
Alot of these parts are available online from www.lithiatoyotaparts.com or kbox.ca
for ones that dont show up on lithia, you can call them, and ask to speak to aaron. he's a cool guy who is very familiar with the gen 3.
Hope that helps some of you guys doing your maintinence on your swaps ect!
Replies (1 - 9)
post Apr 2, 2011 - 9:35 PM
enderswift
Joined Jul 12, '08
this is great
post Apr 2, 2011 - 11:01 PM
mak5603
Joined Oct 20, '08
Great resource for 3rd gen swappers! Wish it was here a couple weeks ago, haha tongue.gif
Oh, and the link to Lithia Toyota is Lithiatoyotaparts.com. Just noticed it was backwards up there.
2014 Toyota Rav4 XLE
post Apr 3, 2011 - 6:49 AM
post Apr 4, 2011 - 11:35 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Now as far as the engine overhaul kit goes, what all actually is in the kit?
2001 Solar yellow Lexus IS300
post Apr 4, 2011 - 12:33 PM
mak5603
Joined Oct 20, '08
QUOTE (96stgreendemon @ Apr 4, 2011 - 9:35 AM) *
Look it up...haha
Going to be typical rebuild stuff, and going to cost an arm and a leg I'm sure.
This post has been edited by mak5603: Apr 4, 2011 - 12:34 PM
post Apr 4, 2011 - 2:18 PM
match220
Joined May 13, '06
From Kaimuki, HI
turbo manifold step-down-studs m12/1.25 to m10/1.25.
If you need to replace the studs in your manifold that hold on your turbo, no other Toyota application that I could find uses them. No other auto dealer could help me find this size of a step-down-stud. Other than having a m12 stud milled down to m10 on the other side, the only option I could find was buying an aftermarket stud made for an old landcruiser when a manifold swap is done. One manifold uses m12 studs, another uses m10 studs. People swap manifolds and need the step-down-stud. One website that I found makes them.
part number 044-02x is the m12/1.25 step down stud.
http://www.sor.com/sor/products2.tam?xax=1...page%23.ctx=044 is the site that you go to.
I spoke with a sales rep at SOR, he says they have the m12/1.25 m10/1.25 step down stud. The length is 36mm. Price is $3.93 a piece.
This post has been edited by match220: Aug 24, 2011 - 6:59 PM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Apr 4, 2011 - 2:23 PM
celiracer
Joined Oct 5, '05
From NE
the overhaul kit is about 24o i believe. not sure receipt not with me lol. but it includes pretty much every seal and gasket the 3rd gen has including all of the gaskets and seals for the turbo. only thing i noticed not in my kit was the oil dip stick o ring and therm gasket lol.. also comes with oil retainers . I went with one because i wanted every gasket and seal replaced on my engine before i put it in.
post Apr 4, 2011 - 4:39 PM
QUOTE (96stgreendemon @ Apr 4, 2011 - 12:35 PM) *
All the gaskets and seals for a complete rebuild.
And yes, it's expensive.
post Dec 5, 2012 - 7:07 PM
dkdmonk
Joined Nov 23, '12
From Troy, IL
Hey I tried that water pump number (16110-88460) and couldn't find it.
I did find 16100-79235 in a different thread but it wouldn't come up either.
I spoke with Aaron at Lithia and he said 16100-79236 is the new number for gen 3 water pump (he said it was the same MR2 and ST205 gen 3).
Can someone else confirm?
Thanks,
This post has been edited by dkdmonk: Dec 5, 2012 - 7:10 PM
Lo-Fi Version Time is now: August 29th, 2026 - 6:24 PM
