> No turn signals/hazards...weird????, Checked 10amp turn fuse and flasher relay, (good), ???
post Apr 25, 2011 - 5:42 PM
injection
Joined Jan 10, '11
From Trail BC
I really need you electric gurus here, no turn signals and hazards, I checked the 10amp turn fuse on driver side fuse box, (good) checked flasher relay, (good), pulled flasher relay out to test circuit with a test light, I got no power going to this circuit with key in accessary position, what is going on with my car?????? Is there supposed to be a constant power there? Please leave some feedback for me, I'm kinda screwed here..thanx bowdown.gif
Replies (1 - 3)
post Apr 26, 2011 - 2:18 AM
kamax
Joined Apr 29, '03
From lynn,ma
check if the hazard light switch is plugged in. happen to me once
post Apr 26, 2011 - 10:19 AM
burningice1989
Joined Dec 5, '09
From Harlingen, tx
QUOTE (kamax @ Apr 26, 2011 - 2:18 AM) *
i second this. i had the same issue when i had to take out my center to install my sound system. it was just the hazzard button plug in the back.
post Apr 26, 2011 - 4:40 PM
injection
Joined Jan 10, '11
From Trail BC
QUOTE (burningice1989 @ Apr 26, 2011 - 11:19 AM) *
Well, think you guys could be right, my centre console is out right now...meaning hazard button isnt plugged in, rolleyes.gif just did 205 swap, and putting everything back together, never thought of that..thanx for the tip! Will try that tonight when out in the garage, will let you know by post...
Lo-Fi Version Time is now: August 31st, 2026 - 4:37 AM
