> ST205 W2A IC On a 5sfte
post Apr 29, 2011 - 4:02 AM
NWCelica
Joined Oct 16, '07
From Seattle
I'm wanting to put one on my soon to be turbo'ed 5sfe. Has anyone done this? Any fitment issue?
Thanks
Replies (1 - 12)
post Apr 29, 2011 - 7:55 AM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Fittment issues - huge as the ST205 throttle inlet in in the middle of cylinder 2 & 5 and the 5S is side inlet.
Still doable but with loads of fabrication. Easier to go front mount.
post Apr 29, 2011 - 9:13 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Frozenboost kit?
Mike W
269awhp / 273ft-lbs
post Apr 29, 2011 - 10:03 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
QUOTE (jeffrosie @ Apr 29, 2011 - 8:55 AM) *
Fittment issues - huge as the ST205 throttle inlet in in the middle of cylinder 2 & 5and the 5S is side inlet.
Front mount would be the easiest/cheapest way!
JDM ST205
post Apr 29, 2011 - 6:11 PM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Dont see why it wouldnt work. then again, dont see why you would want to do it. Should work if you use either a 3rd or 5th gen intake manifold. The Intercooler MIGHT be a bit loose due to lack of mounting holes that would normally be on the 3sgte yet not on the 5sfe. Otherwise, dont see why it would work.
(\__/)
post Apr 30, 2011 - 7:04 PM
delusionz
Joined Feb 11, '08
major clearance issues, you'd have to cut off and make longer mounts on the w2a and tack on some nuts to the head, then the bonnet wouldnt close because the fe head is taller than the g* head. the g* head is recessed to fit the w2a in the same space as an fe head normally takes.
also a 3s-gte intake manifold could be used though, with a custom S-bend throttle body mouth to meet the raised intercooler
Mike W
269awhp / 273ft-lbs
post May 1, 2011 - 5:42 AM
3WayStunna
Joined Jun 25, '06
QUOTE (delusionz @ Apr 30, 2011 - 7:04 PM) *
Good points...dont see it being a worthwhile endeavour...frozen boost kit though,or one of those barrel chargecoolers..oh yea!
(\__/)
post May 1, 2011 - 5:50 AM
delusionz
Joined Feb 11, '08
Mike W
269awhp / 273ft-lbs
post May 1, 2011 - 7:24 AM
3WayStunna
Joined Jun 25, '06
Ever thought about adding a swirl pot/header tank as well? Just a few other thoughts after reading too much of a certain persons post on a certain forum lol...
(\__/)
post May 1, 2011 - 7:27 AM
3WayStunna
Joined Jun 25, '06
QUOTE (delusionz @ May 1, 2011 - 5:50 AM) *
Btw are you making up your own ice box, or going with something pre-made..lol, completly forgot to ask you this. Would like to see what you come with either way!
(\__/)
post May 1, 2011 - 7:55 AM
delusionz
Joined Feb 11, '08
Custom, boot mounted, extra water pump, run hoses through firewall and under carpet (yeah there will be a buldge)
ive got alot of ideas in my head on how to keep ice particles out of the impeller , and how to stop the ice from blocking the flow.
it involves sectioning off areas and some mesh, but yeah ideas for trick design are in my head
Mike W
269awhp / 273ft-lbs
post May 1, 2011 - 2:11 PM
3WayStunna
Joined Jun 25, '06
But yea the mesh should work well enough to keep the ice out. What type of intercooler are you planning on running. Keeping stock, or something newer?
(\__/)
post May 1, 2011 - 2:56 PM
delusionz
Joined Feb 11, '08
OEM FTW
Mike W
269awhp / 273ft-lbs
Lo-Fi Version Time is now: August 28th, 2026 - 8:59 PM
