Jul 10, 2011 - 3:50 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
Im doing a rear disc convertion and would like to upgrade the rotors to slotted and drilled and get good brake pads. I did some reserch but i couldnt get too much info on this.
While i do this swap i guess i dont have to change my proportioning valve because st and gt use the same ones correct? I know brake pads from 94-95 to 96-99 are different on a gt but rotors are different too? I saw this one what you think? If there are better ones for the same price or close let me know please. http://cgi.ebay.com/ebaymotors/Premium-Ser...=item5ae1634292 -------------------- ![]() |
Jul 10, 2011 - 8:23 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
Before you buy, read this:
http://www.celicatech.com/forums/showthrea...ors-quot-Thread |
Jul 10, 2011 - 11:10 PM
Before you buy, read this: http://www.celicatech.com/forums/showthrea...ors-quot-Thread Im not a member of that forum and i cant read it.. can you copy and paste what it says please? -------------------- ![]() |
Jul 10, 2011 - 11:14 PM
Jul 11, 2011 - 2:02 AM
You might want to join, there's quite a bit of cross-traffic between these two forums.
The first post from that thread is quoted below. ============================================================ QUOTE Since I know folks will be eventually asking about this I figured it would be better to head off this disaster before it gets ugly. Here is the response I made to a different forum a few months ago after collecting some information:
=========== QUOTE (mattyboyl) This won't be heated because it's nothing personal. He has an opinion and my opinion happens to be different. Life goes on. It should be a good discussion however. Tune in for more. Well, except that he is right and you are wrong. Allow me to pick apart your theory... First, lets get some physics. Tell me how a heatsink with less mass will cool better? You do realize that a brake rotor acts as a large heatsink to transfer heat from the brake pads to the rotor. The heat generated from pads has to go somewhere and so it transfers to the rotor and caliper. Porsche claims: "Discs are cross-drilled to enhance braking in the wet. The brakes respond faster because the water vapour pressure that builds up during braking can be released more easily." They have said nothing about enhancing normal braking circumstances and the larger diameter rotors probably make up for the lack of material present in a smaller cross drilled rotor. From Wilwood's website: QUOTE Q: Why are some rotors drilled or slotted? A: Rotors are drilled to reduce rotating weight, an issue near and dear to racers searching for ways to minimize unsprung weight. Drilling diminishes a rotor's durability and cooling capacity. Slots or grooves in rotor faces are partly a carryover from the days of asbestos pads. Asbestos and other organic pads were prone to "glazing" and the slots tended to help "scrape or de-glaze" them. Drilling and slotting rotors has become popular in street applications for their pure aesthetic value. Wilwood has a large selection of drilled and slotted rotors for a wide range of applications. As for the porsche rotors, a few notes from a forum I frequent: QUOTE 1) The holes are cast in giving a dense boundary layer-type crystalline grain structure around the hole at the microscopic level as opposed to drilling which cuts holes in the existing grain pattern leaving open endgrains, etc, just begging for cracks. 2) The holes are only 1/2 the diameter of the holes in most drilled rotors. This reduces the stress concentration factor due to hole interaction which is a function (not linear) of hole diameters and the distance between them. 3) Since the holes are only 1/2 as big they remove only 1/4 as much surface area and mass from the rotor faces as a larger hole. This does a couple of things: It increases effective pad area compared with larger holes. The larger the pad area the cooler they will run, all else being equal. If the same amount of heat is generated over a larger surface area it will result in a lower temperature for both surfaces. It increases the mass the rotor has to absorb heat with. If the same amount of heat is put into a rotor with a larger mass, it will result in a lower temperature. 3) The holes are placed along the vanes, actually cutting into them giving the vane a "half moon" cut along its width. You can see that here: This does a couple of things: First, it greatly increases the surface area of the vanes which allows the entire rotors to run cooler which helps prevent cracks by itself. Second, it effectively stops cracking on that side of the hole which makes it very difficult to get "hole to hole" cracks that go all the way through the face rotor (you'll get tiny surface "spider cracks" on any rotor, blank included if you look hard enough). That's why Porsche rotors are the only "crossdrilled" rotors I would ever consider putting on my car. BTW, many of the above features are not present in older Porsche brakes. The above is for "Big Reds" and newer. This is quite different from the standard drilled rotors you get from brembo/kvr/powerslot/"insert random ricer parts brand name here" brake rotors. Further proof of the uselessness of cross drilled rotors are found here: http://www.teamscr.com/rotors.htm QUOTE Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the 40’s and 50’s, not a whole lot. Rotors were first ‘drilled’ because early brake pad materials gave off gasses when heated to racing temperatures – a process known as ‘gassing out’. These gasses then formed a thin layer between the brake pad face and the rotor, acting as a lubricant and effectively lowering the coefficient of friction. The holes were implemented to give the gasses ‘somewhere to go’. It was an effective solution, but today’s friction materials do not exhibit the same gassing out phenomenon as the early pads. For this reason, the holes have carried over more as a design feature than a performance feature. Contrary to popular belief they don’t lower temperatures (in fact, by removing weight from the rotor, the temperatures can actually increase a little), they create stress risers allowing the rotor to crack sooner, and make a mess of brake pads – sort of like a cheese grater rubbing against them at every stop. (Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it.) The one glaring exception here is in the rare situation where the rotors are so oversized (look at any performance motorcycle or lighter formula car) that the rotors are drilled like Swiss cheese. While the issues of stress risers and brake pad wear are still present, drilling is used to reduce the mass of the parts in spite of these concerns. Remember – nothing comes for free. If these teams switched to non-drilled rotors, they would see lower operating temperatures and longer brake pad life – at the expense of higher weight. It’s all about trade-offs. From Stoptech: QUOTE Which is better, slotted or drilled rotors? StopTech provides rotors slotted, drilled or plain. For most performance applications slotted is the preferred choice. Slotting helps wipe away debris from between the pad and rotor as well as increasing the "bite" characteristics of the pad. A drilled rotor provides the same type of benefit, but is more susceptible to cracking under severe usage. Many customers prefer the look of a drilled rotor and for street and occasional light duty track use they will work fine. For more severe applications, we recommend slotted rotors. That almost sounds like an excuse to use cross drilled rotors, and for your street car which probably is never driven on the track, the drilled rotors are fine, but as Stoptech states, they will crack and are not good for severe applications. From Baer: QUOTE "What are the benefits to Crossdrilling, Slotting, and Zinc-Washing my rotors? In years past, crossdrilling and/or Slotting the rotor for racing purposes was beneficial by providing a way to expel the gasses created when the bonding agents employed to manufacture the pads...However, with today’s race pad technology, ‘outgassing’ is no longer much of a concern...Slotted surfaces are what Baer recommends for track only use. Slotted only rotors are offered as an option for any of Baer’s offerings." Then from Grassroots Motorsports: QUOTE "Crossdrilling your rotors might look neat, but what is it really doing for you? Well, unless your car is using brake pads from the '40s and 50s, not a whole lot. Rotors were first drilled because early brake pad materials gave off gasses when heated to racing temperatures, a process known as "gassing out." ...It was an effective solution, but today's friction materials do not exhibit the some gassing out phenomenon as the early pads. Contrary to popular belief, they don't lower temperatures. (In fact, by removing weight from the rotor, they can actually cause temperatures to increase a little.) These holes create stress risers that allow the rotor to crack sooner, and make a mess of brake pads--sort of like a cheese grater rubbing against them at every stop. Want more evidence? Look at NASCAR or F1. You would think that if drilling holes in the rotor was the hot ticket, these teams would be doing it...Slotting rotors, on the other hand, might be a consideration if your sanctioning body allows for it. Cutting thin slots across the face of the rotor can actually help to clean the face of the brake pads over time, helping to reduce the glazing often found during high-speed use which can lower the coefficient of friction. While there may still be a small concern over creating stress risers in the face of the rotor, if the slots are shallow and cut properly, the trade-off appears to be worth the risk. (Have you looked at a NASCAR rotor lately?) And then, let's check out what was said on the aforementioned Altima thread [[[ Long thread at altimas.net that was deleted by that server. it is hosted here ]]]: QUOTE Here is how it works. The friction between the pad and rotor is what causes you to stop. This friction converts your forward energy into heat (remember Einstein: Energy is neither created nor destroyed, it is converted). Now that heat is a bad thing. Yes it is bad for the rotors but it is a lot worse for the pads. A warped rotor will still stop the car - it will just feel like ****. Overheated pads however WILL NOT stop the car. It is here where the rotors secondary responsibility comes in. Its job now is to DISSIPATE the heat away from the pads and DISPERSE it through itself. Notice that DISSIPATE and DISPERSE are interchangeable? Once the heat is removed from the pad/surface area it is then removed. Notice where the removal falls on the list of duties? That's right - number 3. Here is the list again. Memorize it because I will be using it a lot in this post: #1 Maintains a coefficient of friction with the pad to slow the forward inertia of the vehicle #2 DISSIPATE the heat #3 REMOVE the heat from the brake system Let's look more in-depth at each step now shall we? No? Too bad assclown we are doing it anyway. #1 Maintains a coefficient of friction with the pad to slow the forward inertia of the vehicle: This one is pretty simple and self-explanatory. The rotor's surface is where the pads contact and generate friction to slow the vehicle down. Since it is this friction that causes the conversion of forward acceleration into deceleration (negative acceleration if you want) you ideally want as much as possible right? The more friction you have the better your stopping will be. This is reason #1 why BIGGER brakes are the best way to improve a vehicle's stopping ability. More surface area on the pad and the rotor = more friction = better stopping. Does that make sense Ace? Good. Let's move on. #2 DISSIPATE The Heat: Let's assume for a second that the vehicle in question is running with Hawk Blue pads on it. The brand doesn't really matter but that is what I am using as my example. They have an operating range of 400 degrees to 1100 degrees. Once they exceed that 1100 degree mark they fade from overheating. The pad material gets too soft to work effectively - glazing occurs. This means that a layer of crude glass forms on the surface of the pad. As we all know glass is very smooth and very hard. It doesn't have a very high coefficient of friction. This is bad - especially when I am coming down the back straight at VIR at 125MPH. Lucky for us the rotor has a job to do here as well. The rotor, by way of thermal tranfer DISSIPATES the heat throughout itself. This DISSIPATION lessens the amount of heat at the contact area because it is diluted throughout the whole rotor. The bigger the rotor the better here as well. The more metal it has the more metal the heat can be diluted into. Make sense? This isn't rocket science here d00d. #3 REMOVE the heat from the brake system: Now comes your favorite part of the process. This is what you thought DISSIPATION was. It is ok. I will allow you to be wrong. This is the step where the rotor takes the heat it DISSIPATED from the pads and gets rid of it for good. How does it do this? By radiating it to the surface - either the faces or inside the veins. It is here where cool air interacts with the hot metal to cool it off and remove the heat. Once again there is a reoccuring theme of "the bigger the better" here. The bigger the rotor, the more surface area it will have which means more contact with the cooling air surrounding it. Got it? Good. Now let's look at why cross-drilling is a bad idea. First - as we have already established, cross-drilling was never done to aid in cooling. Its purpose was to remove the worn away pad material so that the surfaces remained clean. As we all know this doesn't have much of a purpose nowadays. Next - In terms of cooling: Yes - x-drilling does create more areas for air to go through but remember - this is step 3 on the list of tasks. Let's look at how this affects steps 1 and 2. The drilling of the rotor removes material from the unit. This removal means less surface area for generating surface friction as well as less material to accept the DISSIPATED heat that was generated by the friction. Now because of this I want to optimize step one and 2 since those are the immediate needs. If it takes longer for the rotor to get rid of the heat it is ok. You will have a straight at some point where you can rest the brakes and let your cooling ducts do their job. My PRIMARY concern is making sure that my car slows down at the end of the straight. This means that the rotor needs to have as much surface as possible to generate as much friction as possible and it needs to DISSIPATE the resulting heat AWAY from the pads as quick as possible so they continue to work. In both cases x-drilling does nothing to help the cause. Now let's talk about strength - and how x-drilled rotors lack it. This one is simple. Explain again just how drilling away material/structure from a CAST product DOES NOT weaken it? Since you are obviously a man of great knowledge and experience surely you have seen what can happen to a x-drilled rotor on track right? Yes it can happen to a non-drilled rotor as well but the odds are in your favor when pimpin' bling-bling drilled y0! Since you are also an expert on thermodynamics why not explain to the group what happens to a cast iron molecule when it is overheated. I will give you a little hint - the covalence bonds weaken. These bonds are what hold the molecules together boys and girls. You do the math - it adds up to fractures. So why don't race teams use them if they are so much better? Consistency? Hmmmm . . . no. I am gonna go with the real reason her chodeboy. It is because of several factors actually. They are as follows but in no particular order: - Less usable surface area for generating friction - Less material to DISSIPATE the heat away from the pads - Less reliable and they are a safety risk because of fatigue and stress resulting from the reduced material And what are the benefits? Removal of particulate matter and enhanced heat removal. I gotta tell ya - it is a tough choice but I think I am going to stick with the safe, reliable, effective-for-my-stopping needs solution Tex. Thank you, please drive through. ====================== So basically, buy them if you think they look cool, but not if you think this will be an acceptable performance upgrade. This post has been edited by Galcobar: Jul 11, 2011 - 2:07 AM |
Jul 11, 2011 - 3:29 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) |
your fronts do most of the braking so for the rear my suggestion is to run OE pads. They brake plenty well enough, being the rear heat will never be an issue and of all the pads they dust the least.
This post has been edited by Cuts_the_Pilot: Jul 11, 2011 - 3:30 AM -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
Jul 11, 2011 - 12:09 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
what about 315mm rotors for the Gt-4 where can i buy 4 315mm rotors to have big brakes on all 4 wheels...maybe buy 2 front calipers and put them in the rear
Jul 11, 2011 - 1:09 PM
what about 315mm rotors for the Gt-4 where can i buy 4 315mm rotors to have big brakes on all 4 wheels...maybe buy 2 front calipers and put them in the rear Im pretty sure wont fit and is not necessary to have them that big on the back...al menos q en paraguay hayan muchas bajadas jaja pero igual 4 pistones para atras seria mucho -------------------- ![]() |
Jul 11, 2011 - 2:35 PM
I have 17" rims So it should fit, I also have spacers on...I was just curious as how 4wd with even 4 wheel 4 pot brakes would handle or will I spin out?
Jul 11, 2011 - 7:32 PM
the rear brakes were smaller for a reason, you dont want to lock your rears before your fronts and loose control of the car....
the rear calipers of the gt4 are sufficient enough... i have never believed in slotted and or crossdrilled. I like my car to look like a sleeper. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Jul 11, 2011 - 7:49 PM
I heard slotted rotors will eat the *^%@ out of your pads
I heard slotted rotors will eat the *^%@ out of your pads -------------------- |
Jul 12, 2011 - 1:24 AM
Ive got slotted on my 205, they do increase the braking slightly (also increase the wear rate of the pads slightly)
If your not going to be pushing the car hard getting slotted rotors is pointless (i guess you could get them from looks) Im not a fan of cross drilled, i know people who have used them, a few heat cycles and they have cracked. -------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
Jul 12, 2011 - 7:56 AM
where did you get them?
Jul 12, 2011 - 9:58 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Im not a big fan of slotted or drilled rotors at all. I abuse the hell out of my car and from what ive learned so far, either some fresh new blanks or resurfaced rotors in combination with some good pads (good meaning good heat range for what your brakes will more than likely be dealing with. Also good type of material) is all i or anyone would even need for mild setup....
Although the posted information brought to us by GALCOBAR is mostly true, it dosent really go to far to mention what most of us tuners should actually try to attain in terms of a good brake setup for a mildy tuned, street driven car. For example this article..Dispels alot of myths about the braking system in general. Also mentions that is you want to STOP better. Your best off investing in a good set of stickier tires!! http://www.scirocco.org/faq/brakes/pulpfriction/pfpage1.html http://www.carbibles.com/brake_bible.html This post has been edited by 3WayStunna: Jul 12, 2011 - 5:27 PM -------------------- (\__/)
Jul 12, 2011 - 11:20 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) |
I've said it before, I'll say it again. Brembo blanks and OEM pads. Cheap and does work.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
I've said it before, I'll say it again. Brembo blanks and OEM pads. Cheap and does work. +1 to this!! I have 17" rims So it should fit, I also have spacers on...I was just curious as how 4wd with even 4 wheel 4 pot brakes would handle or will I spin out? In regards to this, look up a term called "brake bias". NJCCMD2002 hit it on the head when he says that you dont want your rears locking up before the fronts. I witnessed what can happen with this myself when a friend of mine installed R32 GTR calipers in place of his stock calipers on his GC8 hoping for a cheap brake upgrade. Needless to say, he went out driving that night and had to slam on his brakes to avoid hitting a car....that caused his rear end to get air-borne and slam (coming down) into a tall a$$ center median...destroyed his entire rear subframe and rear left wheel... Here is a nice detailed article on brake bias, courtesy of google. http://sports.racer.net/brake_bias.htm This post has been edited by 3WayStunna: Jul 12, 2011 - 5:36 PM -------------------- (\__/)
Jul 12, 2011 - 11:47 PM
there is a rubber seal when you remove the spindle and plate whats the part number?? need the rear ones both sides
Jul 13, 2011 - 4:35 AM
The O-ring between the hub and the knuckle? Not sure, bought mine by going into the dealer and explaining what I needed. Check toyodiy.com perhaps.
This post has been edited by Galcobar: Jul 13, 2011 - 4:35 AM |
Jul 14, 2011 - 7:26 PM
The O-ring between the hub and the knuckle? Not sure, bought mine by going into the dealer and explaining what I needed. Check toyodiy.com perhaps. Got the o ring thanks man I saw 2 brembo blanks rear rotors both for 60 shipped are they that cheap? -------------------- ![]() |
Jul 14, 2011 - 7:32 PM
Yep.
Jul 23, 2011 - 4:34 PM
Are the rotors from gt and st the same? I search but couldnt find anything
Jul 23, 2011 - 8:44 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 22, '06 From Columbia, MD Currently Offline Reputation: 13 (100%) |
i have EBC slotted. they are great rotors, paired with the EBC red stuff which is good for streeting and occasional track. i am planning on stepping up to Yellow stuff though for a more aggressive bite on the track
-------------------- ![]() 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Jul 24, 2011 - 9:58 AM
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
EBC Ultimax are also awsome and don't bite your rotors as much as green stuff + don't need to be warmed up, although they are quite a cheap pad they are really responsive and compared to OEM or pads you can get at auto stores are a much better pad.
Also slotted does make a difference but its more so with heat! |
| Lo-Fi Version | Time is now: August 26th, 2026 - 2:54 AM |
