> taking apart gt4 / ssIII spoiler, need info
post Jul 31, 2011 - 10:12 PM
martinmr2
Joined Jun 15, '11
From Orangeville, Ontario, Canada
ok, i'm trying to take the riser blocks off from the spoiler. Each side has these two things that look like rivets. Do i need to drill them out to take the rises blocks apart from the spoiler?
thanks,
Martin
Replies (1 - 10)
post Aug 1, 2011 - 7:38 PM
martinmr2
Joined Jun 15, '11
nobody took apart their gt4 wrc spoiler?
This post has been edited by martinmr2: Aug 1, 2011 - 7:39 PM
post Aug 1, 2011 - 8:44 PM
Valo666
Joined May 15, '05
From Toronto
gimme a call man, I'll take a look at it for you. I'm around tomorrow and on the weekend.
post Aug 2, 2011 - 5:47 PM
martinmr2
Joined Jun 15, '11
hey,
i'll call you on the weekend.....
thanks,
Martin
post Aug 3, 2011 - 3:30 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
my spoiler blocks have holes on the bottom where you can fit a tube thingy to unscrew the little bolts or studs or whatever the hell it is...
post Aug 3, 2011 - 5:30 PM
martinmr2
Joined Jun 15, '11
QUOTE (Neon90424 @ Aug 3, 2011 - 3:30 PM) *
thanks, i took off the 2 10mm bolts and the 3 little scews that keep the bottom cover on. Just need to figure out the studs / rivets part......
Martin
post Aug 4, 2011 - 7:33 PM
richee3
Joined Jun 29, '08
From Denver
Metal or plastic rivets? I'm thinking they pull right off with some pressure.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 4, 2011 - 8:37 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
yeah, they have one way screws, its a tough one ...
Mike W
269awhp / 273ft-lbs
post Aug 4, 2011 - 10:11 PM
martinmr2
Joined Jun 15, '11
looks like metal ( aluminum). I'm thinking about drilling them out, than use bolts to keep the 2 parts together. Also when i took out the 2 10 mm bolts, i noticed that the nuts on the back side became lose and are now rattling in the spoiler. I have to take it apart and do it properly......
Martin
post Aug 4, 2011 - 11:20 PM
delusionz
Joined Feb 11, '08
perhaps a smalll stud extractor
they must be m6 in there ...
Mike W
269awhp / 273ft-lbs
post Aug 27, 2011 - 6:43 PM
martinmr2
Joined Jun 15, '11
well, i took care of it today. Drilled out the top caps of the studs until they fell off. Then i just lifted off the risers and removed the threaded studs from the spoiler end by hand. Not too hard, just took some time. Will put together with regular bolts. Have to now prep and paint the spoiler, than drill the hatch for the new bolt pattern......
Martin
Lo-Fi Version Time is now: August 23rd, 2026 - 4:25 AM
