> how to remove the sunroof cover?
post Aug 3, 2011 - 7:59 AM
Por2geezcelica
Joined Aug 17, '08
From NY
Hey guys, i was wondering if anyone knows how to remove the sunroof cover? I am switching my tan headliner to a gray headliner, but the sunroof panel seems like its difficult, or even impossible to remove. Has anyone successfully removed it? If so please let me know the trick!
Replies (1 - 11)
post Aug 3, 2011 - 8:37 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
If your talking about that cover that slides over the hole in the headliner, then you have to drop the whole sunroof assy.
post Aug 3, 2011 - 8:59 AM
Por2geezcelica
Joined Aug 17, '08
From NY
i was worried that was the only way...
How much work is involved in removing the sunroof?
post Aug 3, 2011 - 11:50 AM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
man removing the sun roof is a biatch! ive done it on my 95 grandprix gtp i had...well let me rephrase removal was easy, reinstall was the issue. but when i removed it i had to remove cover and that came out before anything else.... edit: looked on autozone.com's repair info and seems above poster is correct looks like the whole glass/sunshade assembly comes out as one peice and you need to undo drive motors and all that jazz...sign up to autozone.com and you can see the repair guides, went to the bgbtech site but they didnt offer much assistance in removal help...good luck..
This post has been edited by opie_7afe: Aug 3, 2011 - 12:36 PM
post Aug 3, 2011 - 5:45 PM
mkernz22
Joined May 10, '10
From MA
it's pretty simple to remove.
take off the roof liner, then unbolt the motor near the front of the car.
then unclip the drain lines and undo all the nuts holding the sunroof up.
after that, you unclip the plastics surrounding the glass on the inside and then you can unbolt the glass.
there's a few other bolts and screws to remove, but it shouldn't be too, too hard.
post Aug 3, 2011 - 6:03 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Just remember that the rectangle trimming surrounding the sunroof on the headliner needs to be removed before trying to remove the headliner
94 Celica gt white (sold)
post Aug 4, 2011 - 7:43 AM
Por2geezcelica
Joined Aug 17, '08
From NY
Yep got it! Headliner is out, just need to get the cover off. Maybe I'll just get fabric paint and paint it on the car lol.
Has anyone gotten it out from the inside by pulling it and bending it?
post Aug 4, 2011 - 3:05 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
you bend it i highly doubt you will get it back together, and that fabric paint sucks it makes it all hard and not soft anymore, could always bring it to a upholsterer if you cant cover it yourself
post Aug 4, 2011 - 10:05 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
It does come out, Ive taken mine out, just cant remember how. I do know that I did slightly damage one of the slider things on it, it still works, just not as smooth. And I used the fabric spray on mine, its not like Im going to be all rubbing the headliner anyhow, but if I had to do it again I'd so some suede (or something suede like)
post Jan 9, 2013 - 2:58 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
how do you remove the sunroof glass its driving me up the wall?? I already have the whole assembly out of the car...
post Jan 9, 2013 - 3:41 PM
mindkiller
Joined Apr 6, '12
From somewhere
there is 2 removable plastic covers on each side of the glass under each one 2 nuts.
post Jan 9, 2013 - 4:22 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (mindkiller @ Jan 9, 2013 - 4:41 PM) *
ahh yes thanks much
Lo-Fi Version Time is now: July 7th, 2026 - 5:55 PM
