> What's wrong with my Q window?
post Aug 17, 2011 - 12:00 PM
6GenCircleLghts
Joined Jun 2, '08
It's not off track anymore, but it's extremely wobbly........though I should mention when I went to put it up today it did fall off track and then I did put it back on track. I'll get more pics if you need them to diagnose the problem.
http://s126.photobucket.com/albums/p88/Cwi...;current=QW.mp4
....Anyone from the Cherry Hill area?
This post has been edited by 6GenCircleLghts: Aug 17, 2011 - 12:02 PM
Replies (1 - 7)
post Aug 17, 2011 - 5:56 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (6GenCircleLghts @ Aug 17, 2011 - 1:00 PM) *
X2 i have the same problem:
when u close the front door and roll the FRONT window up, does it interfere with the rear window? like come in the way and/or hit it whenever u close the door?
post Aug 17, 2011 - 9:14 PM
6GenCircleLghts
Joined Jun 2, '08
Malhar95:
That's what mine looked like before I pushed it back onto it's track. Plus where I have it circled, that is now damaged too. Ugh. What would I expect though with 284,000 miles. biggrin.gif
http://s126.photobucket.com/albums/p88/Cwi...current=QW2.mp4
Video - Those three white things(I can't think of the correct term right now) all belong in/on a track. My middle one lost it's backing, so that's why mine is wobbly. I think it's attached to the window so I will have to buy a quarter window. Though the regulator looks like it it's going to break, so I might as well just get one of those too, haha.
Retainer....that must be what fell off the one in the middle.
It would be so much easier to fix if I could access from inside. But no we have that horrible little space to work with. frown.gif
This post has been edited by 6GenCircleLghts: Aug 17, 2011 - 9:17 PM
post Aug 19, 2011 - 11:17 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
all of them do that man, mine goes up crooked now though
post Aug 22, 2011 - 9:40 PM
jlspec
Joined Aug 1, '11
From San Diego, CA
My does that too but onlly when I roll it up with the top down. It seems like the presure of the top pushs it slightly of track. If I put the window up before the top goes then it'll be ok. Only issue is that when I do that and put the top up afterwards I here a loud clicking noise.
1990 Celica Turbo All-Trac, 1977 Celica GT Liftback, 1999 Celica GT Convertible, 2004 Lexus IS300 5-Speed
post Aug 25, 2011 - 9:08 AM
welcome to the world of verts.
the whole assembly needs to be replaced, the one with the bushings, they dont sell the busshings by themselves.
look at my how to..
cost of the assembley 70 bucks.
post Aug 25, 2011 - 11:46 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (njccmd2002 @ Aug 25, 2011 - 10:08 AM) *
look at my how to..
something that is not really shown in the pick is the little stoppers for the top of the track. there should be one in frontside and I think one in the back side
They will stop the window at the exact point you set them. Mabey they fell down to the bottom, but your window should only go so far top up or down.
post Sep 3, 2011 - 8:46 PM
jlspec
Joined Aug 1, '11
From San Diego, CA
While trying to fix my window not going up issue, I fixed and corrected my mis align window. After doing the work I found it extremely easy to remove and re align the window.
Things to check and correct.
1: First check the stoppers and make sure they are set correctly.
2: Check to make sure that none of the three white rollers are not broken. (From what you said it sounds like it is broken).
3: If the window does not aligned with the door window, then adjust the rollers by moving it left or right by the two bolts holding it on top.
4: Afterwards if everything is fix and aligned, but the window leaves a gap between the driver window, then adjust the rollers by using the torx socket to move in our out.
Sorry I didn't take any pics, but I'll do a write up of it later, just with no pics.
Lo-Fi Version Time is now: August 26th, 2026 - 4:27 PM
