> Stuck SSQV
post Aug 20, 2011 - 7:00 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
I noticed today that the Tututututu I was hearing wasn't really my BOV going off but actually some sort of compressor surge and that the BOV doesnt open at all...
The rear of the SSQV...Connects to Vacuum line coming from the TB or does it connect to that little plug that comes out the back of the Watercooler?
This isnt my cars engine bay its only for reference as to where things should be connected.
and is it possible my SSQV got stuck some how? do I just flush it with some oil and thinner or what?
This post has been edited by Neon90424: Aug 20, 2011 - 7:02 PM
Replies (1 - 13)
post Aug 20, 2011 - 8:25 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
thats not an ssqv in that pic?
u know the little port next to the idle port under the charge cooler (not connected to it)? should be connected there
ssqv bov needs a manifold feed with vac, u probably plugged into a pre-throttle body feed so u only got boost no vac
Mike W
269awhp / 273ft-lbs
post Aug 20, 2011 - 11:45 PM
Neon90424
Joined Jan 19, '11
That pic isnt my engine bay, just using the chargecooler as reFErence...my SSQV seems to be stuck closed...
post Aug 21, 2011 - 2:10 PM
94_gt4
Joined Jul 27, '11
From calgary
make sure its hooked up like this if you can tell in my ****ty pic...
i guess you probably cant see it very well but when you took off your oem one, there was 2 hoses attached to it at the top and bottim. i blocked off 3 of the 4 of them and hooked it up with one of the top ones...understand?
post Aug 21, 2011 - 2:54 PM
Neon90424
Joined Jan 19, '11
i connected it to the vacuum line and nothing...I spotted a exhaust leak on the adapter that was made for my turbo and the BOV opens when I push it back with a stick so its not stuck...somethings wrong and i Cant figure out what
post Aug 21, 2011 - 5:58 PM
Neon90424
Joined Jan 19, '11
This is my engine bay and how things are hooked up
post Aug 21, 2011 - 8:02 PM
94_gt4
Joined Jul 27, '11
From calgary
youve got a rusty as turbo and a possible fake SSQV, thats all i see. where are the hoses connected to it?
post Aug 21, 2011 - 8:37 PM
Ted95
Joined Mar 8, '09
From Westport, MA
QUOTE (94_gt4 @ Aug 21, 2011 - 9:02 PM) *
thats not a rusty turbo, thats whats the turbo connects too, u see the coupler that connects to the TMIC and the silver thing under the coupler? thats the turbo and that isnt a fake SSQV thats the "Black Limited Edition" SSQV, i have one on my setup, and that vaccum line is correct too.
st205 powered ss3 coupe
post Aug 21, 2011 - 9:22 PM
ST205WRC
Joined Dec 30, '10
From amarillo texas
QUOTE (Ted95 @ Aug 21, 2011 - 9:37 PM) *
i think he was talking about the exhaust housing and yes it is rusty but that doesnt mean anything when it comes to the BOV working.
post Aug 21, 2011 - 10:10 PM
Neon90424
Joined Jan 19, '11
Yeah the hot side has a small coat of rust on it mostly from sitting on its ass for 6 months...the mess with the long blue hose was me trying to figure out where stuff had to go...that goes to my Electronic boost controller and the AEM progressive water injection module...
The little thingamabob in the SSQV moves back with no difficulties...I cant understand why i keep hearing the Tututututu from the air intake and the BOV not moving... I will wash the BOV with some carb cleaner and buy a new hose to it and clean up some of the vac lines see what happens from there...
I ruined the outside of the SSQV with the ****ty ass snap ring from hell why the $#@@ cant they assemble it with the flange from factory how hard is that???
This post has been edited by Neon90424: Aug 21, 2011 - 10:11 PM
post Aug 22, 2011 - 7:03 AM
disconnect the vac line going to the bov. with the car running see if you feel strong suction from that disconnected vac line. if not, try another source for vacuum.
post Aug 22, 2011 - 10:44 AM
94_gt4
Joined Jul 27, '11
From calgary
i was joking guys, chill. but ya, waht ^^that guy said, theres at least 4 vac lines you can tap to, also make sure the thers are blocked off properly.
post Aug 22, 2011 - 11:25 AM
CELL_PROTOTYPE_X
Joined Aug 7, '05
From Columbus OH
I'd make sure it's sitting correctly in the flange. I have the same issue my new hks bov so I'm curious what your solve is. I currently have what I think is a knock off hks bov that works just fine, but I'm thinking the flange is what's causing the new one to not work properly.
post Aug 22, 2011 - 6:45 PM
Neon90424
Joined Jan 19, '11
I ordered a new SSQV, incase I bust this one up cuz I tried a knock off screw adjustable SSQV and it worked fine on my car so its definitely the SSQV gona fill it with carb cleaner, oil or whatever the hell it needs to get fixed...
Lo-Fi Version Time is now: August 22nd, 2026 - 6:11 PM
