> Coolant Leak! Help Please
post Aug 20, 2011 - 7:05 PM
zwithey
Joined Sep 14, '09
From Michigan
I currently have a 1994 Toyota Celica GT Coupe with a T3/T4 Turbo setup on it.
Recently I noticed that coolant was leaking only after the car is shut off. After the car has been sitting for awhile, such as overnight, when I start it it blows a cloud of white smoke then runs normally after that. It does have an oil cooler, not sure if that's the problem though. The coolant overflow tank has also been removed. I was told it could be a lot of things. . Any advise would be awesome!
Thanks,
-Zach
Replies (1 - 7)
post Aug 20, 2011 - 9:21 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
You should start by getting an overflow tank from the junkyard for a few reasons
-when the engine is hot the cap can let water out to relieve pressure which goes into the tank.
-the water coming from overflow outlet or tube could be your leak.
Other than that there are a few hoses around the area of the airbox that either need the hose clamps snugged up and or new pliable rubber hose
post Aug 21, 2011 - 8:04 AM
zwithey
Joined Sep 14, '09
From Michigan
Thanks for the input. I'll give it a shot.
post Aug 21, 2011 - 8:34 AM
is the turbo water cooled?
post Aug 21, 2011 - 11:15 AM
zwithey
Joined Sep 14, '09
From Michigan
It's oil and water cooled I believe. . .
post Aug 21, 2011 - 1:21 PM
are your spark plugs totally white and clean?
post Aug 22, 2011 - 10:41 AM
zwithey
Joined Sep 14, '09
From Michigan
All the spark plugs but one look normal. One of them looks like it was covered in coolant. . . .
post Aug 22, 2011 - 10:59 AM
xrav22
Joined Jul 24, '08
QUOTE (zwithey @ Aug 22, 2011 - 10:41 AM) *
Sounding like a head gasket. It can happen if you use the engine cleaner additives. The gasket has worn to the coolant channel possibly. Good Luck.
Lo-Fi Version Time is now: August 31st, 2026 - 1:33 AM
