Sep 7, 2011 - 11:16 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
i have a 2nd gen 3sgte and an s54 trans. the cluster is usdm. nothing is reading on the speedometer or the odometer. everything else on the cluster works. i also verified that the cluster works.
i tried looking up the speed sensor on alldata... not much help. i need help! i was reading that there are two speed sensors? any tips that will get my odometer and speedometer to work will be appreciated! This post has been edited by garin: Sep 28, 2011 - 1:18 PM -------------------- |
Sep 8, 2011 - 5:39 AM
Its just a wiring mistake on my part when I did the wiring harness for the car. A lot of people make the same mistake as I did when doing the harness because it the circuit is a bit tricky.
Do a search, I remember posting some detailed instructions on how it fix this in someones thread a while back. There is only one speed sensor. This post has been edited by lagos: Sep 8, 2011 - 5:39 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Sep 8, 2011 - 10:06 PM
haha thanks! lol any idea where the tread is?
Sep 11, 2011 - 3:49 PM
Enthusiast ![]() ![]() Joined Feb 28, '11 Currently Offline Reputation: 5 (100%) |
i have a 2nd gen 3sgte and an s54 trans. the cluster is usdm. nothing is reading on the speedometer or the odometer. everything else on the cluster works. i tried looking up the speed sensor on alldata... not much help. i need help! i was reading that there are two speed sensors? any tips that will get my odometer and speedometer to work will be appreciated! i say its just a bad speed sensor. those s54 sensor go out really easy ive had to replace two in the last 6 months on my 3sgte swap |
Sep 19, 2011 - 1:40 AM
i did a little research. can anyone lead me to wiring for the s54/2nd 3sgte swap! thanks
Sep 28, 2011 - 11:45 AM
can anyone shed some light?
Sep 28, 2011 - 4:21 PM
well if memory serves, 2nd gen 3S-GTE's were matched up to a cable driven speedometer transmission. with your swap you would have to build the wiring from the electronic speed sensor to the harness for speed inputs.
Sep 28, 2011 - 5:47 PM
well if memory serves, 2nd gen 3S-GTE's were matched up to a cable driven speedometer transmission. with your swap you would have to build the wiring from the electronic speed sensor to the harness for speed inputs. hes using the S54, AKA the stock trans. there are a couple diagrams in the FI stickys. -------------------- Former Team 5SFTE pro member ;)
| Lo-Fi Version | Time is now: May 28th, 2026 - 1:48 AM |
