> Trunk not opening
post Sep 10, 2011 - 12:23 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
I've had my car for over half a year now and I have not been able to open the trunk with my ignition key. Is there a different key I should have or do you think something is just stuck in there?
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
Replies (1 - 13)
post Sep 10, 2011 - 7:18 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
does the key turn (either way) when u try to open it?
post Sep 10, 2011 - 8:04 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
you're missing your master key, what you have is the vallet key, i have 2 keys one opens it one doesn't because its meant to be given to the vallet
This post has been edited by freddy121389: Sep 10, 2011 - 8:04 PM
post Sep 10, 2011 - 8:54 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
also, the vallet key's base is triangular. the master keys are rectangular.
another way to check is the vallet key cannot lock or open the passenger compartment.
if you can lock or open the passenger compartment, it is the cable then. thats should be an easy fix.
God made man....
Everything else...
Made in China
post Sep 10, 2011 - 9:09 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
It wont go in all the way nor will it turn. I'll have to try the glove box but I don't think it opens it. How would I get a "master" key?
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Sep 11, 2011 - 2:44 AM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
You could take the lock to a key making place. They charged me the equivilent of $50 american
post Sep 11, 2011 - 4:21 AM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (NYp8tBaller07 @ Sep 10, 2011 - 7:09 PM) *
God made man....
Everything else...
Made in China
post Sep 12, 2011 - 6:17 AM
KeliErons
Joined Sep 12, '11
From USa
post Sep 12, 2011 - 6:39 AM
Culpable04
Joined Apr 17, '06
From New Jersey
for a new key, go to the dealer, they can make you a new one with your VIN number, price varies, by my local dealer charges 4 dollars for this.
post Sep 12, 2011 - 2:45 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (KeliErons @ Sep 12, 2011 - 4:17 AM) *
God made man....
Everything else...
Made in China
post Sep 12, 2011 - 3:08 PM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
Thanks guys; it's not a big deal just wondering what I could do to get one that worked
Power in Balance
90 ST coupe- Sold
02 Impreza RS- DD
post Sep 12, 2011 - 5:30 PM
richee3
Joined Jun 29, '08
From Denver
The lock cylinder is probably seized. Too much corrosion. The lock on the black Celica that I just swapped was the same way. The cylinder worked one day, and the next it didn't. I could stick the key in but not turn it. I could still open the trunk from inside the car but that was it. I took the lock cylinder to a locksmith to have it rebuilt and it cost me $130 because they had to order virtually every part new. However, assuming yours isn't as corroded, it should only cost about $30.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 12, 2011 - 7:00 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
not trying to thread hijack here but how hard is it to switch from cable to electric motor like the one that unlocks the doors
post Sep 12, 2011 - 7:11 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (Neon90424 @ Sep 12, 2011 - 5:00 PM) *
to pop the trunk? you need the solenoid for that. search dustin's thread.
God made man....
Everything else...
Made in China
Lo-Fi Version Time is now: September 8th, 2026 - 7:06 PM
