> Idle Air Control Valve...., Is it under throttle body???
post Oct 2, 2011 - 9:40 PM
injection
Joined Jan 10, '11
From Trail BC
forced engineers!
Is the IACV, under the throttle body, if so, is it a sensor, or can someone give me some detail on what it looks like, because I know the TPS is on the right of the throttle body if you were lookin at it straight on from the front of our cars, then there is the other sensor on the bottom left of it, but dont recall whats under the throttle body, is the IACV directly under it, or on the bottom of it???????
thanx for some details, peace,
Replies (1 - 8)
post Oct 2, 2011 - 11:21 PM
yes its under the TB. its mounted on the bottom and has a 3 wire plug on it. there are also 2 coolant lines on it. it a valve that allows less air in when the engine is cold so it runs richer. Its similar to an automatic choke. when the engine warms up it lets more air in.
post Oct 3, 2011 - 12:48 AM
trdproven
Joined Aug 2, '05
From Guam
try not to round those screws, they are sensitive. clean out your IAC real good and your car will run smoother. if you mess up the screws just use a long nose vice grip, to turn it, once its loose use your fingers. also have spare screws matching for it. GL!
This post has been edited by trdproven: Oct 3, 2011 - 12:48 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 3, 2011 - 9:34 AM
injection
Joined Jan 10, '11
From Trail BC
Thanx for the detail Smaay, I should have no troubles now, I hope this is the reason why my car doesnt like to idle on initial start-up in the morning until it warms up for 3-4 minutes, then idles perfect....TRD thanx for the caution on the screws, I will have long nose vice grips ready at my side, regular carb cleaner with a clean rag should take care of it right?? smile.gif
post Oct 4, 2011 - 1:40 PM
yeah thats all you need. as for the screws use a real good #2 screwdriver and alot of downforce. they are a soft brass screw and love to strip out.
post Oct 4, 2011 - 5:12 PM
an impact screwdriver (harbor freight has em for under 10$) is your best friend with those screws for the IAC.
chances are you'll strip at least one of them out before you get em loose without it, i've yet to strip one with it.
post Oct 4, 2011 - 5:47 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
I was experiencing the exact same issue, I changed the fuel filter and took off the top mount intercooler and shot carb cleaner via a straw down in the hole leading to the iacv. Now it idles up on the 1st cold start like it should and not run bad or cut out at all. So far that is smile.gif also sprayed the carbon built up around the butterfly in the throttle body
This post has been edited by cax_11: Oct 4, 2011 - 5:49 PM
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Oct 4, 2011 - 7:09 PM
trdproven
Joined Aug 2, '05
From Guam
impact helped for 2 but also messed up 2 for me entirely. its also good to use a screw bit that attached to a 1/4 ratchet have used this method on other cars.
Cax, it does kinda work but is not the best, i've tried that too, didn't work its best till i removed the IAC entirely and cleaned it.
QUOTE (injection @ Oct 4, 2011 - 12:34 AM) *
Thats exactly what was going on with my car the last few years. Didn't actually get to it until i did research.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 4, 2011 - 8:30 PM
injection
Joined Jan 10, '11
From Trail BC
Wow! you guys are the A-Team tongue.gif , ( Modern Times of course ) I cant fail with all this help, makes me feel like this is the problem for sure! hearing what cax, and trd said about having the same issue...am at work nightshifts for the next 3 days, will post and let you guys know how it goes when off work, biggrin.gif
Lo-Fi Version Time is now: September 2nd, 2026 - 8:41 PM
