> Need help removing a strip axle nut, anyone with this problem got it solved?
post Oct 28, 2011 - 2:53 PM
chacha
Joined Dec 29, '05
From So-Cal
i have stripped my damn axle nut and can't get it off...tried pb, wd40, breaker bar and now even an impact wrench at 345ft-lb and it still won't turn....it is on the passenger side and now with all those method, the nut is completely destroyed. im so at a lost right now...any ideas i can get this piece of crap off without having to cut the axle or mess up the threads on the axle spindle?
Replies (1 - 13)
post Oct 28, 2011 - 3:01 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if you have access to a welder, weld on the socket, itll allow you to really torque on that thing with a long breaker bar and/or a VERY long pipe.
NO JOKE i used a 20ft piece of pipe to break one... and it still took a lot of effort
post Oct 28, 2011 - 3:02 PM
chacha
Joined Dec 29, '05
From So-Cal
problem is, i can't use the socket anymore because it is so damn stripped...wish i could just drive it to the mechanic shop, but my tires are blown and i needed to remove it so i can change the wheel bearing; breaker bar isn't good if i can't even put a socket on to grip it...they don't make big size nut removers in size 32mm. 32mm just spins freely on the nut and as i down grade to 30mm, it is too small...went standard 1-1/4 and still too big. went with 1-1/8 and that is too small still, im going CRAZY. spent 3-4 days now
This post has been edited by chacha: Oct 28, 2011 - 3:05 PM
post Oct 28, 2011 - 3:04 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
hint: dont put the socket on the nut the whole way to when you weld it. barely put it on the nut, and run a fat bead between the socket and nut.
i mean it doesnt really matter if it goes on or not. as long as its pretty centered on the bolts and you get a good weld between the two.
post Oct 28, 2011 - 3:06 PM
chacha
Joined Dec 29, '05
From So-Cal
damn...wish i could do that, but i don't have any access to a welding tool or a welder. Do you think I can cut it...it looks like soft metal...the nut is from an aftermarket axle found in any kragen or autozone store. i don't mind breaking the nut as i have spares, but i don't want to damage the thread since it is still good.
This post has been edited by chacha: Oct 28, 2011 - 3:08 PM
post Oct 28, 2011 - 3:14 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
theres really no other wway i know of to get it off without damaging the axle
post Oct 28, 2011 - 3:39 PM
spy00005
Joined May 15, '09
From yonkers, NY
You could (i have seen it done and have done it at a autoshop but at your own risk) use a VERY heavy duty center punch and a heavy hammer angle the center punch from the top towards the loosening side and wack it it done right with enough force will loosen it a lil then keep wacking it till it spins although don't do it straight into the axel don't know how to explain it very well.
http://www.dansmc.com/stripbolt.htm
This post has been edited by spy00005: Oct 28, 2011 - 3:40 PM
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post Oct 28, 2011 - 3:52 PM
mkernz22
Joined May 10, '10
From MA
I couldn't get mine off when I was doing my swap so I said f*ck it and just swapped the hubs with my parts car lol
post Oct 28, 2011 - 3:59 PM
spy00005
Joined May 15, '09
From yonkers, NY
ahhh ms paint this is what i mean
gonna need a HEAVY HAMMER and a strong punch tool also make sure the car is on jack stands properly!!!
ALSO I DID SAY AT YOUR OWN RISK
This post has been edited by spy00005: Oct 28, 2011 - 4:03 PM
post Oct 28, 2011 - 4:08 PM
chacha
Joined Dec 29, '05
From So-Cal
thank you for all those response...with it being in the front of the car, it's the hub that has the loop protruding outwards that makes it hard for me to get any room to hit it with. back to point A.
worst of the worst case scenarios, ill have to cut that axle and get a new axle, which im trying to avoid at all cost. just got this axle this summer. don't know if lifetime warranty will cover intentional sawing through the axle.
This post has been edited by chacha: Oct 28, 2011 - 4:10 PM
post Oct 28, 2011 - 5:41 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I had a similar issue, although the nut was not on the axle. I used a die grinder (but im sure that any decent rotatory tool will suffice), but I pretty much cut it off very carefully, as it got close to the threads I used a flathead to break apart the nut.
post Oct 28, 2011 - 7:01 PM
chacha
Joined Dec 29, '05
From So-Cal
thanks, im about had it with the nut...im gonna try to take it to a shop and have them break it in.
post Oct 28, 2011 - 9:00 PM
chacha
Joined Dec 29, '05
From So-Cal
QUOTE (spy00005 @ Oct 28, 2011 - 4:59 PM) *
2 more hours of not giving up and sweaty and salty water running down my face...i chizzled that BITC* till it finally turned...thanks for the motivational pic & talk my fellow 6gc members!! I FINALLY got it...
This post has been edited by chacha: Oct 28, 2011 - 9:01 PM
post Oct 28, 2011 - 9:03 PM
spy00005
Joined May 15, '09
From yonkers, NY
Lo-Fi Version Time is now: August 26th, 2026 - 2:10 PM
