Dec 18, 2011 - 4:37 PM
![]() Enthusiast ![]() ![]() ![]() Joined Nov 24, '07 From Tucson, Az Currently Offline Reputation: 2 (100%) |
I wanted to confirm that the water and oil pumps ARE NOT interchangeable.
are 5SFE and 3SGTE interchangeable? Thanks, Kevin This post has been edited by Soulend: Dec 18, 2011 - 4:43 PM |
Dec 19, 2011 - 5:56 PM
i believe they are. its the timing gear on the crank that must be specific to what cams you use. the water and oil gears are passive so you dont have to worry about them
Dec 21, 2011 - 9:21 PM
I read on a sticky (I believe) that the Oil and Water pumps are not interchangeable... I am curious about the 5SFE parts though. I Think the water pump I replaced was a 5SFE one. I don't know what happened but either the seal was just bad or its something else...
any other information? Kevin |
Dec 23, 2011 - 10:46 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
I know for a fact the water pump is interchangeable. I have the second gen water pump on my 3rd gen, runs just fine
Dec 29, 2011 - 1:23 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '09 From Westport, MA Currently Offline Reputation: 6 (100%) |
I know for a fact the water pump is interchangeable. I have the second gen water pump on my 3rd gen, runs just fine x2 -------------------- st205 powered ss3 coupe
Dec 29, 2011 - 5:25 PM
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
a gen2 oil pump have the pressure relive valve in her, which the gen.3 doesn't have becouse it is in the oil pan nr.1, the pump gears are also different the gen.3 pump runs faster here you can see some pictures http://www.gtfours.co.uk/ there are two version of the water pump available, a plastic impeller one with a better design and a stainless one the plasic one is just used on gen.3 GTE's, gen.2, 4 and even the gen.3 GE uses the less powerfull stainless one the pump housing is also specific to the plastic one more about to built a uprated pump in the near future in this thread, if you are interested in this http://www.6gc.net/forums/index.php?showto...t=0&start=0 greetz This post has been edited by Sunny: Dec 29, 2011 - 5:31 PM -------------------- |
Dec 31, 2011 - 2:51 AM
![]() Enthusiast ![]() ![]() ![]() Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
I know for a fact the water pump is interchangeable. I have the second gen water pump on my 3rd gen, runs just fine I do second this, but it's been a while since I changed my waterpump. I vaguely remember having to buy the 2nd gen water pump and use half of it with the other half of the 3rd gen water pump. Something like that. Can someone else confirm or deny? -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
Dec 31, 2011 - 8:36 AM
The waterpump is the same, the back housing is diffrent.
| Lo-Fi Version | Time is now: June 16th, 2026 - 11:39 PM |
