Dec 27, 2011 - 9:35 AM
Enthusiast ![]() Joined Sep 2, '11 From cyprus Currently Offline Reputation: 0 (0%) |
Hello guys
What other solution i have for suspension except tein and trd .is sow expensive :S I saw here some modification to install the bc coilovers , is this safe for the car ? to cut the original and install the bc coilovers ? Why i am asking that ? all the weight of car is in coilover can he hold and be safe when the car runing ?? |
Jan 7, 2012 - 4:51 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 11, '08 From London Currently Offline Reputation: 7 (100%) |
I was the first to review the BC's with the welded bottoms and its been a few years now. Not a single crack or fault has developed.
You're worried about the weight of the car being on them but you're forgetting it's pressing on it not pulling apart. The cosworth's used to have a similar connection with their shocks to the hubs and they're just clamped on for the ralley races. I wouldnt worry if I where you. Just get the BC's as they're the best value for money upgrade you can get for the four. |
Jan 7, 2012 - 8:49 AM
![]() Enthusiast ![]() ![]() Joined Nov 15, '10 From Austria Currently Offline Reputation: 1 (100%) |
Hi,
i also use the BC suspension, and i'am with yellow when he said best value for money upgrade i also use c-one swaybars which makes the more/safer driveable in curves please note that i found ~0,2mm clearance between the oem ss-arms and the BC coilover, so we pressed out the old ss-arm inserts and manufactured a new oversized one and mounted it by heat before we welded both together but some time ago BC was asking for SS-arms to built a plug&play coilover kit, the last i know is that they come in contact with KYB which is the OEM of that arms, so possible they can now offert a full p&p kit greetz -------------------- |
Jan 8, 2012 - 5:09 AM
probably ill go for bc is the cheapest way thnx for the advice guys
| Lo-Fi Version | Time is now: May 7th, 2026 - 7:23 PM |
