> hid blinks?
post Jan 4, 2012 - 11:57 AM
diegohiga
Joined May 4, '09
From coral springs florida US
Hey im having a small problem with my 35w low beam hid. Only left side dim (blink) a little when im driving i changed the ballast and buld. They are brand new and still doing the same thing. And is not because of the sound system because i have a capacitor and it does it with the music off. Problem is only with the left side right side is perfect. Idk its wierd.. haha what could it be???
Replies (1 - 17)
post Jan 4, 2012 - 1:10 PM
bsamps4
Joined May 16, '10
From Raleigh
Have you tried an hid error cancellor?
post Jan 4, 2012 - 1:26 PM
richee3
Joined Jun 29, '08
From Denver
Did you try swapping the bulb and ballast sides individually? Just to rule both out 100%.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 4, 2012 - 2:40 PM
RobbMeeX
Joined Dec 30, '11
From Atlanta via Mobile
Makes me think its a ground issue, though not looking at it, i'm not sure.
QUOTE (Araykhel @ Oct 10, 2011 - 6:32 PM) *
Today I learned that I need a turbo to complete me.
post Jan 10, 2012 - 3:50 PM
celi_wabbit
Joined May 10, '08
From PA
install a capacitor and if you still have issue? add the resistor in there. That's what I did with mine. Bought the parts in Radio Shack and solder it on.
94 Celica GT - Project
93 MR2 - Sold
91 Celica Alltrac/GT4 -Sold
95 Tacoma - DD
post Jan 12, 2012 - 12:32 AM
diegohiga
Joined May 4, '09
QUOTE (celi_wabbit @ Jan 10, 2012 - 3:50 PM) *
capacitor in the hids? where exactly does the capacitor will go? between the switch and lights?
post Jan 12, 2012 - 9:40 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
hids "strobe" when they dont get enough volts. chack the ground in the inner fender frame on that side
post Jan 13, 2012 - 12:17 AM
trdproven
Joined Aug 2, '05
From Guam
HID troubleshooting is pretty simple swap parts around and if it doesn't work, then try getting a dedicated true ground to test because if youve already tried swapping or new and assuming the parts are good, sounds like you need a better ground.
This post has been edited by trdproven: Jan 13, 2012 - 12:17 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 22, 2012 - 5:49 PM
celi_wabbit
Joined May 10, '08
From PA
QUOTE (diegohiga @ Jan 12, 2012 - 12:32 AM) *
Right at the cars positive and negative wire that plugs in to the ballast. It's the original wire that plugs in to the old bulb.
This post has been edited by celi_wabbit: Jan 22, 2012 - 5:53 PM
93 MR2 - Sold
95 Tacoma - DD
post Jan 26, 2012 - 12:07 AM
trdproven
Joined Aug 2, '05
From Guam
theres a bunch of error cancel stuff and other electronics that people talk about but for many cars and hid kits i've seen i've never had to use those nor my friends. Im sure there are certain models that may need it but our cars don't have electrical conflicts like that. at worse some DRLs give problems only because some drls are also the low beam which doesnt provide enough power to the HID.
I'd try another set of HIDs perhaps a different brand and if still no go, try a better ground. I've mostly seen the blinkys from bad ballast. i do hid installs all the time, maybe I haven't experienced anything where my methods have not worked so far.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 26, 2012 - 1:46 PM
diegohiga
Joined May 4, '09
QUOTE (trdproven @ Jan 26, 2012 - 12:07 AM) *
Im going to connect the hids direcrly to the battery. And the hids will get all the ground they need to work properly. If that doesnt work i guess ill get another set of hids.
post Jan 26, 2012 - 6:07 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
I purchased the cheap kit off ebay (xantech? xentech?) for my car. initially mine did the same thing. Car on and at Idle and you can see them flicker. Come to think of it I think it was my left side too. Anyway I was going nuts trying to figure it out. I just left it as is and one day they just stopped flickering. The manual to my bulbs did say they required a "break in period". I honestly can't remember if I followed it or not. Could have been my issue, might be similar to yours.
post Jan 26, 2012 - 10:09 PM
trdproven
Joined Aug 2, '05
From Guam
^ive seen that happen in those cheap ebay kits, sometimes it goes away sometimes it doesn't. its the brand for the most part but particularly seen that problem in the xentec
This post has been edited by trdproven: Jan 26, 2012 - 10:09 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 27, 2012 - 12:09 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
QUOTE (trdproven @ Jan 27, 2012 - 3:09 AM) *
This is probably true as I purchased a much more expensive kit ($150 compared to $30) for my motorcycle which had zero issues.
post Jan 27, 2012 - 11:50 PM
diegohiga
Joined May 4, '09
QUOTE (k-weaver @ Jan 27, 2012 - 12:09 PM) *
Ok decided to get a good brand hids. Whats the best option?
post Jan 28, 2012 - 1:56 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
I've bought quite a few sets of DDM Tuning HID kits in the past for some friends and two sets for myself (both used in projectors) - which are cheap - and never had an issue with any of them. You should get a relay harness to run them too...that might fix the issues you're currently having. HID's when they are first turned on use more amperage at start-up than halogens, even though they are 35w compared to the 55w halogen lights, the current draw in the first few seconds of start-up is considerably more and the wire gauge probably isn't enough to carry the current the HID's require, which is where the relay harness comes into play. Like Stephen said, it could also be a ground issue. Amazon has some relay harnesses for a good price. Either way it wouldn't be a bad idea to run a relay harness either with your current ones to see if it fixes the problem, or on a new set of HID's.
post Feb 6, 2012 - 9:58 AM
hatchy_gt-s
Joined Jan 16, '07
From covington, KY
QUOTE (diegohiga @ Jan 26, 2012 - 1:46 PM) *
It's pointless to attach the ground wire to the battery, the battery just grounds to the body of the car. The issue is a bad ground HIDs' are just a contained arc, it's like a welder if you don't have enough voltage when welding you get a choppy weld.
You should also have a look at your ballasts, change in amperage could also cause that.
post Feb 6, 2012 - 7:54 PM
trdproven
Joined Aug 2, '05
From Guam
Since our cars don't have HIDs it can only be the ground, the ballast or the bulb so it sounds like your ground.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: August 25th, 2026 - 10:02 AM
