> Broken Headlight relay?
post Jan 13, 2012 - 6:51 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
I recently tried fixing one of my lights that were out, so I bought new bulbs (HIDS) and it turns out that the bulb was not the problem. So then I checked the fuses, they were ok but I also pulled out the headlight relay while the headlight switch was on, when I plugged it back in, the headlights would not turn on after that, even with the switch on. I believ e I blew the relay, but If I switch my brights on the headlights work and later I found out that one of my ballasts was broken and that was the problem for the bulb. whenever I have to use my lights I stick a piece of wire in place of the relay and and always stays on unless I remove the wire. I also just got a used headlight relay from eBay but when I installed it, it didn't fix the problem. So I think it could either be the eBay seller gave me a broken relay? or is it something else? Also am I supposed to disconnect the battery when installing a relay? I didnt do that both times
Replies (1 - 9)
post Jan 14, 2012 - 12:01 AM
chacha
Joined Dec 29, '05
From So-Cal
hid have polarity differences...so if you plug it in wrong it won't work...although the connector male to female seem to fit like a puzzle...switch it up...It is harder to explain...just switch the connector by flipping the and turning them around to see if you have the polarity reverse...if reverse, it won't turn on.
one side works and the other dead...reverse the polarity and it should work, if it still doesn't, then the ballast is bad...switch the ballast on the passenger with the driver side and see if it works...test the good ballast with both bulbs to see if the bulbs is bad. usually it is the positive wire and negative wire are plug into the male and female adapter wrong (- from the female to the + male connector) where it should be (- from the female to the -male connector and + female to the + male connector).
post Jan 15, 2012 - 11:48 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
QUOTE (chacha @ Jan 14, 2012 - 1:01 AM) *
I think I get what you mean but understand that the lights work just fine when i use the high beams switch. I will try switching the ballasts around and the connectors like you said. But the use of the switch definitely failed after I unplugged the relay and plugged it back in when the switch was left on. How do I check if the relay is broken?
post Jan 16, 2012 - 12:05 PM
chacha
Joined Dec 29, '05
From So-Cal
oh...if you switched it when the light what still on...that will definitely blow out the ballast...just hope you have warranty still and tell them the ballast is bad. don't tell them you switch it out by unplugging while the lights were left on...power surge killed it buddy.
post Jan 17, 2012 - 8:59 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
QUOTE (chacha @ Jan 16, 2012 - 12:05 PM) *
Ballasts are fine I already switched thebad one. If I place a wire between the relay terminals to replace the relay and it works, its the relay right?
post Jan 18, 2012 - 2:35 AM
chacha
Joined Dec 29, '05
From So-Cal
don't know about that one...never had to put a wire in the relay terminals...anyone else?
post Jan 25, 2012 - 5:16 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
bump...
post Jan 25, 2012 - 11:30 PM
199celica
Joined Jul 29, '11
From chino, Ca
Might seem a little dumb but sometimes when people don't put the relay in right they push the little connector holding onto the relay down did you make sure all of the connections are at the same height bud? that was my problem with my anti theft fuse and relay.
post Jan 27, 2012 - 10:45 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
QUOTE (199celica @ Jan 26, 2012 - 12:30 AM) *
Yea each time I put the relay back in, I'm able to have the headlights working only when I am pulling my hi beams switch, so it must be plugged in right. I just ordered an automotive mutimeter though, so I'm really going to get to the bottom of this.
This post has been edited by DIONYZUZ: Jan 29, 2012 - 12:53 PM
post Feb 24, 2012 - 3:43 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
Yea it was the relay, an eBay seller sent a USED relay but it was actually a broken one... tested it in my multimeter and there was no resistance
Lo-Fi Version Time is now: May 20th, 2026 - 4:10 PM
