Jan 22, 2012 - 3:22 PM
Enthusiast ![]() ![]() Joined Jan 17, '06 From Wisconsin Currently Offline Reputation: 0 (0%) |
Hello I just replaced both rear hard lines on my 94 GT celica with rear disk brakes. While the lines were out I believe most of the fluid drained out of the rear lines and the master cylinder.
-I am currently trying to bleed my rear disk brakes with my Mityvac suction bleeder which I have used with success in the past on this vehicle but this time when I open both rear bleeders nothing comes out, no fluid..... -I have tried pumping the pedal with it closed and there is nothing changes, pedal feels somewhat firm not soft. -I have tried pumping the pedal with the bleeder open while the mityvac is sucking and pumping the pedal, still no fluid.... -Has anyone had a problem bleeding rear disk brakes after replacing both hard lines and system is dry??????? Any ideas???? Thanks...... |
Jan 22, 2012 - 5:07 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
try removing the bleeder and seeing if its not blocked you can put a small needle it...if it wont come out you can try heating it and putting that penetrating oil on the grooves
Jan 22, 2012 - 9:02 PM
THanks for the reply, sure enough I pulled the bleeders and both were plugged from the line rusting out!!!!
Thanks again,, Brandon |
| Lo-Fi Version | Time is now: August 24th, 2026 - 12:05 PM |
