> Rough idle
post Jan 26, 2012 - 3:08 PM
Unholy
Joined May 28, '11
From Oklahoma
Recently I have been having a ton of problems with my celica shaking only when in drive when stopped. If I put it in neutral it mostly goes away.
I haven't really started looking at much to fix the problem because I just didn't know where to start.
If you need more info just ask.
Replies (1 - 8)
post Jan 26, 2012 - 3:17 PM
SupraKid
Joined Aug 15, '10
From The Best Coast
Maybe one of the mounts is gone. When was the last time the car got a tune-up?
post Jan 26, 2012 - 3:23 PM
Unholy
Joined May 28, '11
From Oklahoma
I took it too a local mechanic and he looked at somethings and said he couldn't figure it out. I did a tuneup in summer. My dad checked the motor mounts and he said that they looked new.
a little more info:
It idles around 600-700 and if I press on the gas and get it up atleast to 800 or a 1000rmps it runs just fine.
And sorry I was unsure where to put this thank you for moving it to the right section. smile.gif
post Jan 26, 2012 - 4:48 PM
check them again, where in OK are you, ill actually be in OKC next week, i can check it out for you
post Jan 26, 2012 - 11:02 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
It's possible you're tranny isn't disengaging the way it should when you press on the brake. Maybe a faulty switch. I assume this is an automatic by the way you're talking?
When is the last time you cleaned out the throttle body and linkage? Maybe there is some dirt preventing the IAC valve from opening the butterfly enough.
But you said it runs fine in neutral, so that leads me to believe it's transmission related. Check your fluids, a possible tranny oil change is in order, and have a shop check your shift solenoid, (if they exist on these cars, never dealt with an AT Celica directly before) or any other sensors that may be in line to brake to tranny relation.
post Jan 27, 2012 - 3:53 PM
Unholy
Joined May 28, '11
From Oklahoma
I'm out of state for my birthday right now.
I haven't had this car but like 3 month and in that 3 months I haven't got to do anything with it.. The people that had it before me I don't think took very good care of the car.
It is an auto.
And when I get back I will take it to a shop and have them check that and look into cleaning the throttle body and linkage and report with my results.
post Feb 11, 2012 - 2:52 PM
Unholy
Joined May 28, '11
From Oklahoma
It ended up one of the engine mounts. They said it would be about 300 to have it fixed.
post Feb 11, 2012 - 3:02 PM
It's never just one mount. Replace both side mounts and the front mount. You can DIY with hand tools and a floor jack.
post Feb 11, 2012 - 3:13 PM
Unholy
Joined May 28, '11
From Oklahoma
They said It's the crossmember mount? I am working on getting a jack and I will be able to.
Lo-Fi Version Time is now: August 2nd, 2026 - 4:11 PM
