> Very odd set of issues involving start up, Battery wont have power sort of.
post Feb 12, 2012 - 11:39 PM
HaysoosKreesto
Joined Nov 4, '09
From Sacramento, California
Well... ok so, my 98 recently had two episodes that would seem as if the battery would need to be replaced.
1) Was at a park, and the car was still warmish from a fresh drive and it wouldn't start. The odd thing is that when I tried to turn over the engine, all of my lights on my dash died and nothing started. When I got a jump I noticed that my dash clock and stereo clock were forward by 20 minutes and the battery ran the whole drive and several days afterwards absolutely fine with no problems at all. This was the first episode.
2) After work today, the car was cold because it was off for 5 hours in the cold. Once again, the lights on my dash were fine upon key entrance but when I went to turn the motor all the lights died and the battery needed to be jumped again, however, this time both clocks were forward by 2 hours... Once again, after the jump the battery will drive just fine with no signs that it needed to be replaced during the drive (I mean like no dimming of anything, the headlights seemed normal, and no odd sounds).
I'm guessing that my battery is probably either the incorrect size, or hopefully this will never happen again. So I guess my main question is =>
Has anyone ever experienced a dead battery and time shift?
Replies (1 - 6)
post Feb 13, 2012 - 8:38 AM
sounds like bad battery connections or cables.
post Feb 13, 2012 - 2:54 PM
sounds exactly like poor connection at the terminals. one of my celicas does this same thing. get ya a 10mm wrench and loosen the terminal clamps. wiggle them a bit and re-tighten. you should be good to go
post Feb 13, 2012 - 10:18 PM
HaysoosKreesto
Joined Nov 4, '09
QUOTE (Smaay @ Feb 13, 2012 - 2:54 PM) *
You rule Smaay, I've seen you help countless people and you continue to do so!
I swear a freakin 10mm wrench solves everything with this car lol
post Feb 15, 2012 - 5:19 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
QUOTE (Smaay @ Feb 13, 2012 - 12:54 PM) *
I'd be tempted to apply a little steel or copper wool to the connectors and terminals first, then hit them both with dielectric grease to ensure a clean connection with corrosion prevention.
post Feb 15, 2012 - 9:32 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (Galcobar @ Feb 15, 2012 - 5:19 PM) *
Galcobar and Smaay are on the right track. This happened to my Celica about 3 months ago; went outside on particularly cold morning, turned the key, and all electronics in the car just shut off. Seeing as I had a brand new Optima Yellowtop in the car I knew the battery was dead so I disconnected the battery terminals, cleaned them with baking soda, a bit of water, and a toothbrush, and then re-connected them. Car fired up on the first turn of the key. Problem solved.
Has no more Celicas
post Feb 15, 2012 - 9:50 PM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
toyotas are built with 10 and 14mm lol almost everything besides suspension is a 10 or a 14
This post has been edited by 4-eyed-freek: Feb 15, 2012 - 9:50 PM
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
Lo-Fi Version Time is now: July 29th, 2026 - 7:55 AM
