Feb 14, 2012 - 10:15 AM
Enthusiast Joined Apr 5, '08 From Kentucky Currently Offline Reputation: 0 (0%) |
Hey guys,
My 97 Celica GT just started popping out of 5th gear. I can cruise at lower speeds with it staying in gear, but when I accelerate at all, it will pop out. 5th gear is the only gear that it will pop from. All other gears are just fine. Any ideas? May have to replace transmission? -Justin |
Feb 14, 2012 - 11:51 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
sometimes if a shifter cable is loose, etc. it can cause a gear poping out issue. Other than that you'd have to take apart the transmission and see whats going on exactly with 5th gear.
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Feb 14, 2012 - 4:17 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
What's your gear oil at level wise?
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. ![]() *ASE Certified General Manager |
Feb 16, 2012 - 9:29 AM
Enthusiast ![]() ![]() Joined Jan 16, '12 From 860, ct Currently Offline Reputation: 0 (0%) |
You too? I completely lost 5th after having it pop in and out for a week. Also lost reverse temporarily; I ended up pushing the car out of a parking spot the same night 5th turned into noisy neutral, but after doing that, it seems to work now.
Really annoying having to cruise at 4300rpm at 70 in 4th, right? My gear oil was full (of little chunks). It also drained 2plus quarts. |
Feb 16, 2012 - 9:36 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Feb 16, 2012 - 1:23 PM
I still have 1-4 though! I have no choice but to rive as-is, with any luck, it won't die 200 miles from home at the tip of my commute.
| Lo-Fi Version | Time is now: July 28th, 2026 - 3:38 PM |
