Feb 16, 2012 - 11:49 PM
![]() Enthusiast ![]() Joined Oct 4, '09 From Pomona, CA Currently Offline Reputation: 1 (100%) |
So i upgraded my 7a to the 3sgte wrc version. I am running a e153 trans.
![]() ![]() ![]() My clip came with these awesome Jdm gauges
-------------------- The heart has its reasons which reason knows nothing of
2000 7th gen GTS 6spd 95 st, swapped 3sgte 3rd gen wrc version :D |
Feb 17, 2012 - 1:46 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 4, '09 From coral springs florida US Currently Offline Reputation: 21 (100%) |
very nice girl!! im in the same route
This post has been edited by diegohiga: Feb 17, 2012 - 1:52 AM -------------------- ![]() |
Feb 17, 2012 - 10:20 AM
you only need a spacer for the passenger axle. a stock ST185 (all-Trac) axle will work for the drivers side.
Erynn, did they get all the gauges to work on your cluster This post has been edited by Smaay: Feb 17, 2012 - 11:11 AM -------------------- 2001 Celica GT-S Turbo
Feb 17, 2012 - 1:19 PM
you only need a spacer for the passenger axle. a stock ST185 (all-Trac) axle will work for the drivers side. Erynn, did they get all the gauges to work on your cluster We used axels off the mr2 with some slight modifications including parts off s camry axel from the junk yard PM maksed man or urbandork they can give you exact info I'll have to get details on that. Yes Jeff, Craig wired it up perfectly. -------------------- The heart has its reasons which reason knows nothing of
Feb 18, 2012 - 5:18 PM
Enthusiast ![]() Joined Nov 24, '10 From Worth, IL Currently Offline Reputation: 5 (100%) |
you only need a spacer for the passenger axle. a stock ST185 (all-Trac) axle will work for the drivers side. Erynn, did they get all the gauges to work on your cluster We used axels off the mr2 with some slight modifications including parts off s camry axel from the junk yard PM maksed man or urbandork they can give you exact info I'll have to get details on that. Yes Jeff, Craig wired it up perfectly. Why is everyone talking about spacers. I got '90 Camry axles and didnt use any spacers. Its a off the shelf part. Why is everyone swapping inners and outers for like Mr2 inners and st185 outers. And by the way ST185 didnt fit my '94 GT hub, splines too big so info online is inaccurate. '90 Camry axles+six flange bolts+axle nut=lots of time for multiple 6-packs. Im using Lexus ES300 E153 LSD trans, with Lexus driver side flange and MR2 turbo LSD pass side jack-shaft/axle extension, and '90 Camry axles both are same L or R. And I think Camry is atlest as wide as St20x Celica unlike MR2 or St185/st165. |
Feb 19, 2012 - 12:19 AM
you must have got a ST165 axle. the ST185 axles fit perfectly in 6th gen hubs...and 7th gen.
Feb 19, 2012 - 2:30 PM
you must have got a ST165 axle. the ST185 axles fit perfectly in 6th gen hubs...and 7th gen. I dont know but when I got them I got them specifically for 93 Alltrac in US, and they were exactly like my LSD turbo MR2 one I had. Besides actual axle shaft size wast different too. But '90 Camry fit with no issues just saying, dont have to play with no grease. |
Feb 20, 2012 - 12:23 PM
you only need a spacer for the passenger axle. a stock ST185 (all-Trac) axle will work for the drivers side. Erynn, did they get all the gauges to work on your cluster Last question in thia threat lol evryone says you need spacers when you combine the mr2 and st185 axles but nobody says how thick it needs to be. How thick???? -------------------- ![]() |
Feb 20, 2012 - 1:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
Nice!
Feb 27, 2012 - 10:02 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) |
Nicely done - time to move it to the "My Project" section and tell us your story...
| Lo-Fi Version | Time is now: August 21st, 2026 - 2:30 PM |
