> Battery relocation wiring
post Mar 19, 2012 - 8:46 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
I have seen the previous thread discussing this, but my case is a little different. I am going to be running 0 guauge from the hood to the trunk of my car. I am also going to make my own battery box, but what wires am I connecting exactly? I bought a battery harness and the battery wires were cut off. I know there is a black and white cable that connects to the main fuse in my fuse box so I am assuming one of them as well as one wire to the starter? What about the alternator wire? Does the alternator wire connect to the batter, the starter or the main use block?
Harness is from a 97 celica st and the other electrical system should be from a 94 celica st
Replies (1 - 4)
post Mar 19, 2012 - 10:17 PM
199celica
Joined Jul 29, '11
From chino, Ca
i can help you out but i don't highly understand what you mean by cut. if you can provide a pic. man i can help you out a little bit more
post Mar 19, 2012 - 10:51 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
on a different note im considering finding a new place for the battery back in the engine bay, i think for handling reasons, these cars are front heavy on purpose
Mike W
269awhp / 273ft-lbs
post Mar 20, 2012 - 6:13 PM
richee3
Joined Jun 29, '08
From Denver
Where the positive battery terminal used to be, splice your 0 gauge in there. Leave the alt/starter wires where they are. Run only the 0 gauge back to the trunk, then ground in the trunk as well. You'll want to add a new ground from the trans to the chassis. It sounds more complicated than it really is smile.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Mar 20, 2012 - 10:35 PM
m2736185
Joined Jun 4, '10
From Jax Beach, FL
Yea, if it was a simple relocation I could do it in 20 minutes.
The extra step I am having is I am using a new engine harness where the battery terminals have been cut . So what I need to know is WHAT cables run to the positive side of the battery terminal. Is it just the fuse block and starter cable?
Lo-Fi Version Time is now: September 1st, 2026 - 7:06 PM
