> Lets get down and dirty with a 2ZZ., Experts only please.
post Dec 28, 2003 - 9:35 PM
Guest_Jason_*
A friend and I are looking into taking on a nice project, obviously, attempting to swap a 2ZZ(GTS) into my current 7A(ST). This good friend of mine did the swap on my previous Integra, has alot of knowledge on welding and fabricating etc, but not neccessarily in wiring (which can be dealth with at a later time). We just "out of the blue" started thinking about doing such a swap as a fun project to attempt. We just want to look into some of the difficulties we may run in to before we actually run into the situation with no way out. Basically, trying to plan out all of our problems ahead of time, so that when we reach them, we have a planned method of working around them.
What i'm asking is, if anybody can give me some possible difficulties we may run into and some helpful solutions to getting around them or making them work, please help. Our most obvious is Engine Mounts, but we aren't worried about that at all really, its pretty easy to weld new mounts on. The good thing on this is that all work is going to be done by him, making installation free unless we run into some severe difficulties. Through me some ideas guy...
We are currently trying to get our hands on a low-mileage 2ZZ.
I'm going to go ahead and come out on a limb and say right off the bat we are looking into custom axle's (unless a GT would work), relocated engine mounts, and transmission.
Replies (1 - 19)
post Dec 28, 2003 - 9:48 PM
Just out of curiosity, why spend more money than you would on a 3S-GTE swap for less horsepower? And also, wasn't your old Integra turbocharged, not swapped? Trust me, this swap will be way way harder than nearly all Honda/Acura engine swaps.
post Dec 28, 2003 - 10:08 PM
GeEkBoY
Joined May 17, '03
From Ontario, Canada
If you don't want turbo, the beams red-top is a way better swap than the 2ZZ, here are a few details at this link:
http://www.tuning.cz/lander/beams.htm
post Dec 28, 2003 - 10:39 PM
5sfeTurbo
Joined Apr 14, '03
The mere cost of a "low mileage" 2ZZmotor+Transmission+ECU will kill let alone the friggin install and disecting the wirring diagrams for both vehicles. I think this project would be better left untouched. I mean Im ALL about new ideas but your commiting suicide.
post Dec 29, 2003 - 12:45 AM
macavely
Joined Nov 4, '02
well off the top of my head i can't seam to think of any major problems you'll run into other then getting custom axales if the same don't fit... and unlike everyone else i think it would be a good project... and you can get a wrecked 7gc really cheap... so getting parts might be cheaper then a 3s swap....
if i think of any problems you might have i'll post again..
97sccelica
Joined Aug 30, '02
From Anaheim, CA
well, the main problem will be wiring, since the engine will fit and mount fabrication isnt hard.
it would be better to get a usdm front clip
that way the harness is already lhd oriented and will not have to be lengthened(hopefully)
then the harness will plug into the engine and go to the ecu inside the car through the stock hole in the firewall(again, hopefully)
then you have to figure out how to wire the gauges and get the 6gc HVAC to work with the 2zz AC system.
also, a new radiator may be needed along with custom ac lines, custom hybrid axels, and totally new exhaust among other things
imho, a complete waste of time and money. the 2zz was a lame attempt at beating the b18c5(type r engine right?)
the power band sucks and aftermarket is small.
1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram
post Dec 29, 2003 - 1:49 AM
Guest_Jason_*
Alright, don't take this the wrong way, but I didn't create this topic to get convinced out of the project. When I said getting our hands on the Engine cheap, we found a 7GC GTS with 20+ miles for 600$. All damage was done to the rear only, no problems with the front. This swap HASNT been done, so we kind of thought it would be cool to be the first at attempting this.
The engine is pretty much bought for dirt cheap, so getting the front clip is pretty much done with.
So pretty much the only difficult part is the wiring.
As far as my Integra Coomer, the Integra was a GS with a GSR swap, then it was turbocharged.
post Dec 29, 2003 - 2:15 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
The only hard thing about the wiring will be the gauge hook-ups, IMO. The stock harness should transfer over completely with the ECU, sensors, etc. Of course, you'll have to custom fab plumbing for cooling systems, a/c, etc... and custom mount everything... but I'd say it'll probably be less hassle than any JDM swap... cause for me, custom fab under the hood is not as hard as messing with wiring...
Drivetrain-wise... you can probably use the inner shafts that connect to the tranny, but the outer shafts have to be the right length and have to fit the front hubs. There are options... other than custom, especially since toyota uses similar hub patterns all of the time... but if not, it'll have to be custom.
This post has been edited by Kwanza26: Dec 29, 2003 - 2:33 AM
post Dec 29, 2003 - 2:37 AM
boosted_K2
Joined Aug 30, '02
From Michigan
QUOTE (Jason @ Dec 28, 2003 - 9:35 PM)
why do you want to do this???
my personal view on this option:
1) the 2zz is a capable engine but is very expensive for the power gains.
reasons:
A) you have a baseline of 180BHP, which is around the same of a ST165 3sgte motor. the price differences are marginal. the only difference is VVTL-i VS. Turbo, which i dont see how the VVTL-i would be more inticing.
B) you can turbo the 2zz, but kits are EXTREMELY expensive, around 6k i believe is the price my friend was telling me.
C) for the price of a turbo on a 2zz you can get a T3/T4 kit on the 3sgte and boost to 15PSI on an all stock motor, which is widly done on MR2s. (once you get an adjustabl FCD, which you can do for 5 dollars with a custom black box)
2) The 2zz requires just as much if not more custom work as a 3S -> ST swap.
A) the block is completely different, just like the 3S, so it will need new engine mounts, the difference: theres a version of the 6gc with the 3S, so customizing is minimal compared to the 2ZZ.
B) the 2zz wont work with either the 3s, 5s, or 7a axles or trans, unless you do a custom bell housing adaptor, which can be CnC milled from aluminum, but its not an easy task. then you would have to research clutch sizes, fittings, patterns, etc .
C) the 2zz has completely different wiring, so nothing will be plug and play, it will all need to be meshed togeather if you were to use all the stock emmenities.
i will probably post more later.
No but I don't buy it
Cause I'm...
post Dec 29, 2003 - 2:43 PM
SpedToe169
From Dallas, Tx
As most of you said, wiring is the hardest thing. Axles are a non-issue. Its not hard to get custom axles made (www.raxles.com). Just use the 6-speed that comes with the motor and you won't need any adaptors, so no prob there. Motor mounts you'll have to totally pull out of your a55, but if your friend is as good as he thinks he is it wont' be a problem. Fabrication of that sort really isn't that bad.
I do think the gages will be a problem. I'd be surprised if you can get the speedo to work correctly. Might just be easier to go with aftermarket gages. Also getting the hvac stuff working will be tricky. Might be easier just to take the hvac panel out of a 7gc and figure out how to make it work in the 6.
The more I think of it, wiring really shouldn't be that bad. You'll be using a US harness so everything is in the right place. All the sensors should still be in place on the motor and tranny, and you'll have the ecu. There shouldn't be much splicing of wires at all.
My overall take: This swap is easier than everybody thinks. The hardest part of the whole thing is not making the car run and drive, but making all the auxillary systems work correctly.
post Dec 29, 2003 - 6:16 PM
GeEkBoY
Joined May 17, '03
you may want to consider an aftermarket ecu to control the engine and leave the stock one to take care of the other systems. This could help with the compatability issues.
post Dec 29, 2003 - 11:36 PM
Guest_Jason_*
You think using the 6SPD Transmission will bolt right in with no problems at all?
I'm not all that worried about standard system things. It would be pretty simple to get my hands on a Tach, and other things like A/C etc aren't much of a concern.
post Dec 30, 2003 - 4:40 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (SpedToe169 @ Dec 29, 2003 - 7:43 PM)
Exactly what I said... everyone is just so damn negative about this engine for some reason... Major wiring, sensors, etc should all swap over directly with ECU. Only problems would be tach, speedo, odometer, etc...
And Jason... yes you can use the 6speed tranny. No reason why not... There shouldn't be any fitment problems or anything like that. It bolts up to the engine and nothing else (aside from maybe a motor mount). What K2 says about the bellhousing doesn't apply because you'll be using the tranny that comes with the motor (better be the 6speed and not the auto). Although, you'll also have to get all of the shift linkages and gearbox and stuff... probably custom make some stuff there also. Aside from that, the only other thing is getting the correct length axles with ends that fit the tranny and the 6th gen front hub.
This post has been edited by Kwanza26: Dec 30, 2003 - 4:41 AM
post Dec 30, 2003 - 4:58 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (GeEkBoY @ Dec 29, 2003 - 11:16 PM)
Not necessary... the stock ECU, when swapped over, should be able to control everything related to the swap...
post Dec 30, 2003 - 7:12 AM
VlaCelica
Joined Nov 10, '03
From Netherlands
QUOTE (Jason @ Dec 30, 2003 - 4:36 AM)
Yes it is done before, and its easy to do. A guy from our celica club called blackjack (he is also member of this forum) has done it already. So i dont think that will cause any problems.
But when looking at this whole project i would think its a big waste of money and time. I cant image why anyone would ever like that engine isntead of a 3sgte or a beams engine.
Btw, the 7th gen GTS engine around here (netherlands) has 192 BHP.
post Dec 30, 2003 - 1:57 PM
SpedToe169
From Dallas, Tx
An aftermarket ECU is a really bad idea with this engine. Its going to be very difficult or near impossible to get an aftermarket ecu to control the VVTL-i. The only application where a stand alone would make sense is in a full on race application where you'll be grinding custom cams and you don't care about anything below 6k rpm.
post Dec 30, 2003 - 10:18 PM
Guest_Jason_*
Okay, here's what i've compiled from alot of this.
- Size wise, the 2ZZ will fit right in my Engine Bay w/o problems.
- 6SPD Transmission should fit with minor customization, but should line up fine.
- Custom Axle's will need to be made.
- Keep stock 2ZZ ECU.
- New Motor Mounts to be welded.
- No serious wiring problems besides Gauge Cluster (Speed, Tach)
Sounds decent enough, and very doable.
post Dec 30, 2003 - 11:08 PM
SpedToe169
From Dallas, Tx
Yup, I think you've got it. Like I said, the auxillary stuff will be the hardest. Getting the AC, cruise, and gages working properly.....
post Dec 30, 2003 - 11:17 PM
GeEkBoY
Joined May 17, '03
Uhmmm....
I think you are giving us too much credit. There is no way we will have told you all the problems you are going to see. I have had in-depth experience with a 97 GM electrical system and that was no walk in the park.
The 2ZZ will be looking for an ABS control unit, Airbag control unit, some cars have a body control unit (not certain if toyota uses it for the 2ZZ. All of the units go throught the ECU, and the ECU may not like it if they are not present.
Get your hands on an electical wiring diagram for a celica GTS (or watever ECU and wiring harness you get). If you or anyone who is helping you does not know how to read them.... good luck!
Once you understand the electrical system, you will know what systems you need from the 2ZZ, and which ones you can adapt from the 6gc
post Dec 31, 2003 - 8:47 AM
Guest_Jason_*
I understand Geekboy, thanks man.
Well, wish me luck. I'm going to go ahead and have a mechanic look at the GTS Engine and Transmission, then hopefully buy it next week then have it shipped to my friends Garage.
Lo-Fi Version Time is now: September 13th, 2026 - 1:23 PM
