> Lower Control Arm Bolts Continually Loosening?, Anyone have this issue?
post Apr 15, 2012 - 11:20 PM
zonz540
Joined Jul 3, '09
From UT
Ive been having major problems with my lower control arms lately. The bolts that thread into the frame in the center of the control arm (largest bushing) continually come loose, which has resulted in stripped out threads on the frame. Ive had the frame drilled and tapped, but that only worked for a month or so.
All bolts are torqued to the recommended 116 ft/lbs (according to the Toyota repair manual).
I swapped out to poly bushings on the front end and have Eibach Sportlines/KYB GR-2's with 17" TC rims and 205 40 R17 tires as of about two years ago. (Pretty rough ride sometimes, i can only imagine what the suspension goes through...)
Anyone have issues with this kind of thing, or possibly some advice?
This post has been edited by zonz540: Apr 15, 2012 - 11:23 PM
Replies (1 - 2)
post Apr 16, 2012 - 12:33 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
use thread locker red
post Apr 18, 2012 - 3:56 AM
6gcer
Joined Apr 17, '12
From SoCal
Replace the bolt and use loctite
Lo-Fi Version Time is now: August 27th, 2026 - 12:43 PM
