> Scraping noise when turning right not backing plate
post Apr 26, 2012 - 2:36 PM
nonsgard
Joined Aug 9, '10
i have a 1994 celica st and it makes a scraping noise like metal on metal when im turning right its coming from the passenger front side. it only happens when im driving. i lifted up both sides and put it in drive and no noise. and i know for sure its not the backing plate .
Anyone can help me
This post has been edited by nonsgard: Apr 26, 2012 - 2:36 PM
Replies (1 - 3)
post Apr 26, 2012 - 2:38 PM
richee3
Joined Jun 29, '08
From Denver
I'd bet it's your bearing. Turning right puts more pressure on the passenger side bearing. Check and replace it ASAP.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 26, 2012 - 2:41 PM
mkernz22
Joined May 10, '10
From MA
definitely the passenger wheel bearing. depending how bad it is, you might need a new hub as well. Luckily is it fairly easy to take the whole knuckle off and put back on so you can do that part yourself and save money in labor. It was about $200 for me with the seal kit, bearing, and hub. Then you just have to pay labor for the shop to press the bearing onto the hub.
post Apr 26, 2012 - 3:15 PM
nonsgard
Joined Aug 9, '10
thanks guys
Lo-Fi Version Time is now: August 27th, 2026 - 7:55 AM
