> Heated Seats
post Apr 28, 2012 - 6:04 PM
bruiseboy2
Joined Mar 1, '12
OK, so my parents are junking our old subaru outback and it has heated seats in it. I already took out the heating elements and the plugs and wires. How could I wire these seats in into my car, and I want to modify the plastic where the cigarette lighter is so that instead of the empty hole next to it, I have the 2 switches for each seat. So my question is where should I draw power from and what would be the easiest wiring?
Replies (1 - 11)
post Apr 28, 2012 - 6:11 PM
jcbass7
Joined Apr 20, '06
From Florida
I put aftermarket heated seats in my car. I took power from the thick gauge wire going into the ignition, not the constant 12 volts, but the on that puts out power when the key is in. then you just need to wire it all up from switches to the seats. Batman722 has them wired in the cig lighter spot like you are talking about, my switches are on the doors, next to the power lock button.
post Apr 28, 2012 - 6:37 PM
bruiseboy2
Joined Mar 1, '12
So you just spliced the wire going to the ignition?
post Apr 28, 2012 - 7:16 PM
jcbass7
Joined Apr 20, '06
From Florida
I spliced into it yes, just like when you install a factory alarm. For the heated seats you just need a power source from somewhere. I chose that one since it would carry enough amperage over the heavier gauge wire.
post Apr 28, 2012 - 7:27 PM
bruiseboy2
Joined Mar 1, '12
ok sounds good. So when these are in use, do think running my 1000 watt amp to my sub would be too much draw for the alternator? I mean I know our alternator is pretty beefy, but I don't want to end up killing my alternator this winter.
post Apr 28, 2012 - 7:31 PM
jcbass7
Joined Apr 20, '06
From Florida
I don't think it will be a problem, I've run both with no problems
post Apr 28, 2012 - 8:48 PM
http://www.6gc.net/forums/index.php?showtopic=63914
search is fun.
post Apr 28, 2012 - 9:56 PM
bruiseboy2
Joined Mar 1, '12
Thanks, this is a big help. Excited to have some warm seats when I go snowboarding.
post Apr 28, 2012 - 10:20 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
My Celica!
post Apr 28, 2012 - 10:26 PM
bruiseboy2
Joined Mar 1, '12
yerp, snowboarding is the ****. and driving the celica in the snow could not be more fun lol. Who would think a 2 door coupe with some studded snows would do soo much work in the snow lol.
post Apr 28, 2012 - 10:57 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
If you're bored, check out my crew: http://vimeo.com/nexgencrew
My Celica!
post Apr 28, 2012 - 11:42 PM
bruiseboy2
Joined Mar 1, '12
yeah these are the goons I ride with. http://icecoastkills****.com/?p=1565
I cant imagine living in an area without hills. At least you got some good urban riding
Closed TopicStart new topic
Lo-Fi Version Time is now: September 13th, 2026 - 9:50 PM
