May 4, 2012 - 1:45 AM
Enthusiast ![]() Joined Apr 6, '12 From somewhere Currently Offline Reputation: 0 (0%) |
ticking noise coming from under the valve cover when give it gas it will tick faster. any suggestion? valve clearance maybe?
May 4, 2012 - 8:12 AM
Enthusiast ![]() ![]() ![]() Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) |
Had the same problem with my old 7a. Did a check on the clearance and everything was fine. I was told it was rod knock. When i replaced my motor i didnt pull it apart to verify. Wouldnt hurt to check the clearance. I never read up on the supposed rod knock. Something i should do.
May 4, 2012 - 8:22 AM
solid lifter engines like the 7A can be a little tappy. Try a little heavier weight oil if it bothers you. Also injector tick was VERY pronounced at idle, throw a towel over the injectors and listen again. If it is them and they bother you that much you can fashion a cover out of sheet metal and spray foam to cover them to help silence.
May 4, 2012 - 8:24 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
^ What he said. Put your ear right up to the injector bank and you can hear them well.
-------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
May 4, 2012 - 9:24 AM
solid lifter engines like the 7A can be a little tappy. Try a little heavier weight oil if it bothers you. Also injector tick was VERY pronounced at idle, throw a towel over the injectors and listen again. If it is them and they bother you that much you can fashion a cover out of sheet metal and spray foam to cover them to help silence. ^ What he said. Put your ear right up to the injector bank and you can hear them well. This is allll good stuff and right. I had a valve adjustment done two years ago (before that, the ticking was insane) and afterwards, I could still hear a light ticking. It's just the injectors. -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
May 4, 2012 - 10:33 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
solid lifter engines like the 7A can be a little tappy. Try a little heavier weight oil if it bothers you. Also injector tick was VERY pronounced at idle, throw a towel over the injectors and listen again. If it is them and they bother you that much you can fashion a cover out of sheet metal and spray foam to cover them to help silence. ^ What he said. Put your ear right up to the injector bank and you can hear them well. This is allll good stuff and right. I had a valve adjustment done two years ago (before that, the ticking was insane) and afterwards, I could still hear a light ticking. It's just the injectors. Ticking can be annoying, but it isnt bad coming out of the cylinder head. Its knocking that you need to worry about if you hear it. Make sure there isnt an exhaust leak and check your valve clearances. Move your hand around close to the exhaust manifold where it bolts to the head. You will feel hot puffs of air if there is an exhaust leak. |
May 4, 2012 - 2:43 PM
i was thinking about removing the spark plugs wires one by one to see if it will effect the ticking noise, what do you think?
May 5, 2012 - 12:04 AM
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:15 PM |
