> Factory 8" Speaker
post May 15, 2012 - 12:47 PM
jlspec
Joined Aug 1, '11
From San Diego, CA
My 99 Celica Convertiable 8 inch speaker is blown. Does anyone know of a good 8" Mid bass driver that I can use. Current audio setup is just stock. Once I replace the 8 inch speaker I might as well change the rest. Anyone know the size of the stock front speakers?
1990 Celica Turbo All-Trac, 1977 Celica GT Liftback, 1999 Celica GT Convertible, 2004 Lexus IS300 5-Speed
Replies (1 - 19)
post May 15, 2012 - 1:10 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (jlspec @ May 15, 2012 - 12:47 PM) *
If you've got premium sound (8 speaker set-up) then its the 8" in the door and a 4" above that with the tweeters near the side mirrors. I don't remember the rear size.
post May 15, 2012 - 3:28 PM
jlspec
Joined Aug 1, '11
From San Diego, CA
Cool, finding a good 4 inch shouldn't be a problem. What about the 8inch speaker? On my alltrac I got the Kicker SSMB8, but I am unable to find a mid bass driver for the 99 Celica. Kicker doesn't make the SSMB8 anymore, so what would be a good replacement for a 8" mid-base driver?
post May 15, 2012 - 4:26 PM
Syaoran
Joined Jan 4, '12
From US
Madisoundspeakerstore
parts-express
Dunno if this fits, but here's an example. Also check out the "speakers" section.
http://www.parts-express.com/pe/showdetl.c...number=292-2592
As a bit of extra knowledge: when looking at the specs, try to find something that has 4 ohms impedance and a Qts of about .707
Like these: http://www.parts-express.com/pe/showdetl.c...tnumber=290-356
These are actually PERFECT speakers for what you need them: Qts of .70, 3.5mm xmax, 4ohm impedance... only issue might be the mounting depth but if you can make them fit they will definitely sound good.
http://www.parts-express.com/pe/showdetl.c...tnumber=290-310
This post has been edited by Syaoran: May 15, 2012 - 4:36 PM
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post May 15, 2012 - 9:59 PM
richee3
Joined Jun 29, '08
From Denver
The speaker is actually a 6.5" speaker in an 8" bracket. There is actually a debate in a recent thread about whether those speakers in the 8 speaker system are subs or mids, would be nice to get a final definite answer if you can help smile.gif
http://www.6gc.net/forums/index.php?showtopic=83445
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 16, 2012 - 5:04 PM
chucho
Joined Mar 23, '03
From New Orleans
http://www.woofersetc.com/c-106-7-8-and-9.aspx
I have the dynaudio three way setup in my car. But the JL would be good.
post May 16, 2012 - 11:12 PM
jlspec
Joined Aug 1, '11
From San Diego, CA
MW170 - Dynaudio 170mm Midrange/Midbass Speaker
Is this the speaker that you got? If so, how is it running with the stock amp?
post May 17, 2012 - 10:08 AM
Xander_X
Joined Apr 22, '12
From Central NY
QUOTE (richee3 @ May 15, 2012 - 10:59 PM) *
- Agreed, inquiring minds want to know
I would stick with JBL ... they make some nice 8" 2-ways and 8" woofers ... either way you want to go. Soundstream, Infinity, Harman Kardon (JBL, Infinity and Harman Kardon are all made by Harman), MB Quart ... higher end Pioneer, higher end Polk Audio, Massive Audio.
This post has been edited by Xander_X: May 17, 2012 - 10:09 AM
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post May 18, 2012 - 12:58 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
I'm running a set of Focal 210 CA1 -- woven glass cone, and a sealed rear magnet make for great full-range sound and endurance in the less-than-optimal conditions inside the doors.
This post has been edited by Galcobar: May 18, 2012 - 12:58 AM
post May 18, 2012 - 9:05 AM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE (richee3 @ May 15, 2012 - 9:59 PM) *
I've got factory 8in speakers in my front doors. All my other celica's had 6.5's but this car is the premium sound with the two amps etc.
post May 18, 2012 - 2:01 PM
chucho
Joined Mar 23, '03
From New Orleans
QUOTE (jlspec @ May 16, 2012 - 11:12 PM) *
I have the three way setup. It's not on the stock amp it's running on an ARC amplifier. And if you notice the price that's per speaker not for the pair. They sell them individually to be able to buy if one blows.
post May 18, 2012 - 7:45 PM
^^^ at 200 a pop, it better sound good!!!
http://www.amazon.com/MW170-Dynaudio-Midra...r/dp/B004IWLC4Y
post May 18, 2012 - 10:16 PM
chucho
Joined Mar 23, '03
From New Orleans
QUOTE (njccmd2002 @ May 18, 2012 - 7:45 PM) *
My 3Way setup goes for over 1K. They sound awesome but their for SQ and life like reproduction. 200 hour break in time which is crazy.
Not trying to sell you on getting dynaudio because I have just telling you that you can make the 8" work in the doors.
post May 18, 2012 - 10:19 PM
chucho
Joined Mar 23, '03
From New Orleans
Have to have a lot of watts running to this setup. Can't hook it up to a stereo or a small 2 channel amp and expect results. I would say go with the JL 8" middrives for what you want should be a very good sounding speaker and not kill the bank like the dyns.
post May 19, 2012 - 12:44 AM
wow, stil the JL goes for 200 pop
post Aug 19, 2016 - 12:27 AM
TerryE
Joined Apr 27, '08
From Michigan
QUOTE (Syaoran @ May 15, 2012 - 5:26 PM) *
Madisoundspeakerstore parts-express Dunno if this fits, but here's an example. Also check out the "speakers" section. http://www.parts-express.com/pe/showdetl.c...number=292-2592 As a bit of extra knowledge: when looking at the specs, try to find something that has 4 ohms impedance and a Qts of about .707 Like these: http://www.parts-express.com/pe/showdetl.c...tnumber=290-356 ===== These are actually PERFECT speakers for what you need them: Qts of .70, 3.5mm xmax, 4ohm impedance... only issue might be the mounting depth but if you can make them fit they will definitely sound good. http://www.parts-express.com/pe/showdetl.c...tnumber=290-310
Thanks for the info, have the GW208-4's on order, I have been looking for a reasonably priced replacement since my OEM's foam dry rotted out.  - about five years ago, and I didn't want to have rebuild the audio system since it was great to begin with.
This post has been edited by TerryE: Aug 19, 2016 - 12:28 AM
post Aug 19, 2016 - 9:48 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
Meh since someone already bumped this old thread...
I have a 99 GT with the regular 4 speakers n two tweeters.
What's considered an equivalent system that will replace all speakers and sound like that of an 2003 Avalon XL trim.
im not trying to install any subs either. .
thanks
This post has been edited by BonzaiCelica: Aug 19, 2016 - 9:54 AM
post Mar 15, 2018 - 12:58 AM
BonzaiCelica
Joined Apr 24, '08
20180314_194026 by Justin Towers, on Flickr
20180314_194057 by Justin Towers, on Flickr
20180314_194141 by Justin Towers, on Flickr
3.25" depth
20180314_194345 by Justin Towers, on Flickr
2.5" depth
20180314_194431 by Justin Towers, on Flickr
post Mar 15, 2018 - 1:03 AM
BonzaiCelica
Joined Apr 24, '08
i went to crutchfield and they have pics of a 99 celica gt convertible. but the speaker options come in 5.25" and 6.5". custom mounting is the only way it seems.
This post has been edited by BonzaiCelica: Mar 15, 2018 - 1:16 AM
post Oct 1, 2018 - 5:29 PM
Kevinisyoung
Joined May 6, '18
From Brea, CA
QUOTE (TerryE @ Aug 19, 2016 - 1:27 AM) *
How are the GW208-4s? Was there enough room in the vert for them? Sound good? Considering getting this since I ripped out my stock 8s because they were torn to oblivion.
Lo-Fi Version Time is now: July 29th, 2026 - 2:28 AM
