> SRS light in ST205 cluster (Japanese), no SRS light.. how to check SRS system in a GT4?
post Aug 1, 2012 - 6:04 PM
jcbass7
Joined Apr 20, '06
From Florida
Reaching out to the GT4 folks on here, I have a GT4 ST205 cluster in my ST204 celica. While converting the wiring over to match up for the cluster there is no light for the SRS airbag system in the GT4 cluster. Is there a way the GT4 notifies you if the system is not working? I still have the wiring in my car so I can technically just wire in an LED somewhere to check this, but I'd like to get it as close to the GT4 setup as possible.
Thanks!
Will post some pics soon
Replies (1 - 7)
post Aug 1, 2012 - 6:34 PM
mkernz22
Joined May 10, '10
From MA
I believe that certain models did not have airbags in the car
This post has been edited by mkernz22: Aug 1, 2012 - 6:34 PM
post Aug 4, 2012 - 2:12 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
airbags are optional on all jdm models
some have them, mine has it, some dont
the light bulb socket will be blanked out on your cluster, its possible the tracks are there on the pcb and you can put a bulb in it and repin the socket, i personally dont know tho
Mike W
269awhp / 273ft-lbs
post Aug 4, 2012 - 2:18 AM
delusionz
Joined Feb 11, '08
Also what year is it from too?? I actually dont recall seeing a 94-95 jdm celica with airbags, but if they did it would be driver only.
I know its definitely not a model thing they were optional with all 6gens from 1996 onwards
Mike W
269awhp / 273ft-lbs
post Aug 4, 2012 - 7:27 AM
azian_advanced
Joined Apr 18, '05
From Calgary
airbags came optional for 94-95 as well.
post Aug 4, 2012 - 9:01 AM
delusionz
Joined Feb 11, '08
the airbag light is on the right side of the cluster, first bulb on the bottom row, looks like a man with a big ball infront of it.
From what I can remember, my 1995 Celica (non airbag) had a blanked out 4WS light there instead, my 1996 celica (non airbag) had a blanked out airbag light there and ofcourse my 1996 gt-four has airbags so the light is there and goes out a second or 2 after u turn the key
Mike W
269awhp / 273ft-lbs
post Aug 4, 2012 - 9:39 AM
jcbass7
Joined Apr 20, '06
From Florida
i'm not sure what year my st205 cluster is from, but I suppose it was a model without airbags. I'm going to take the warning light panel from my st204 cluster and repin things to work with that so I can still have the SRS light on there. I'll show some pics soon.. I think I have it all figured out, just gotta customize a few more things
post Aug 4, 2012 - 11:18 AM
jcbass7
Joined Apr 20, '06
From Florida
switching from this
to this... (sorry for bad pics)
and that should solve my problem after I re-pin the plugs for it
Lo-Fi Version Time is now: August 29th, 2026 - 11:51 AM
