> New Brake Job
post Oct 8, 2012 - 3:43 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
Hey 6gc,
I wanted to know what else I should do with the new brakes I got. I got some Brembo Blanks in the front and rear and the ebc redstuff brake pads all around, SS brakelines, and I'm going to paint the calipers. I'm waiting on the rear rotors because they are on back order, but in the meantime what should I get? new pins or other parts? I was originally going to do the st205 brakes, but I gave up on the idea and just went with this. I've never replaced my brakes before, so any advice or suggestions will be greatly appreciated.
Replies (1 - 11)
post Oct 8, 2012 - 4:56 PM
mkernz22
Joined May 10, '10
From MA
mr2 turbo front calipers! they're a dual piston and will change the braking bias from a 71f & 29r to about a 65f & 35r which will even the braking out a tad bit more!
post Oct 8, 2012 - 5:27 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (mkernz22 @ Oct 8, 2012 - 4:56 PM) *
no I would not recommend mr2 twin piston calipers. for one that have smaller surface area than gt brakes and second they are biased for a mid engine vehicle (probably not as important on the street, anyhow but would be more of a visual mod than performance upgrade). the twin piston celica calipers really are as hard to acquire as most make it out to be. Most companies just don't put them on up for sale because they think celica owners have no interest in them.
post Oct 9, 2012 - 10:49 AM
DIONYZUZ
Joined Oct 29, '09
From Chicago
Yea I'm thinking of just being set with original calipers, I just want to know if I should get anything else new besides the pads, lines, and rotors. I don't really want anything that custom like calipers from another vehicle, I don't think it would be worth it for me because my GT feels kinda slow anyway. I was thinking of getting this car into decent shape and saving up for a subaru legacy gt or lexus sc300 and give this celica to my sister.
post Oct 9, 2012 - 2:04 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (BonzaiCelica @ Oct 8, 2012 - 6:27 PM) *
I don't understand what you mean by it not being an upgrade? The ideal bias for a car is 60front & 40rear. If the MR2 calipers change the celica from a 71front, 29rear to a 65f & 35r, it's an upgrade. The braking is being distributed more between both the front and rear calipers.
post Oct 9, 2012 - 3:48 PM
BonzaiCelica
Joined Apr 24, '08
http://www.6gc.net/forums/index.php?showtopic=76435
post Oct 9, 2012 - 4:14 PM
mkernz22
Joined May 10, '10
From MA
yes, i've read that a few times already, hence why I bought the mr2 turbo calipers.
this is what i got out of it:
QUOTE (Culpable04 @ Feb 3, 2011 - 1:44 PM) *
QUOTE (bccentaur3 @ Jan 30, 2011 - 2:27 AM) *
Damn so the brake bias gets shifted to the back that's no dice at the track. Although it will take less effort to lock the front up.
not nessesaraly, the " theorical " magic number for brake bias is 60 / 40 ( front / rear ) but that will vary from setup to setup, and the importance of modifying your Bias is to use the most grip available while keeping the front locking first than the rear, so if you think about it, as long as his front is still locking the tires before the rear, it is an upgrade, a good one actually, because it will spread the braking force better among all 4 tires, so all 4 tires will work more efficiently at stoping the car instead of the front ones doing most of the job with a 70+ % of the braking force on the front.
One of my friends tracks his car every season and his brake bias is 58% front 42% rear with an adjustable proportioning valve, he got to those numbers after a lot of trial an error testing. so Norberto, find a safe area where you can test your brakes, have someone look at your tires ( or video ) and make sure your front tires lock before your rear one, if they do, I'll be the first one to call this a great upgrade, best bang for your buck brake upgrade.
QUOTE (Culpable04 @ Feb 4, 2011 - 8:57 AM) *
of course, a car should be setup to the driver's taste, but my point is that, This " upgrade " should be called an upgrade. in a perfect world you would want all 4 tires locking at the same time as this would make all the tires work just as hard stopping the car, but in the real world the front needs to be locked just slightly before the rears, so depending on the weight transfer due to suspension and engine position and of course drivers taste we should modify the bias to make the best out of the setup,. if you look at most adjustable proportioning valve setups they are use to lower the bais on the front not to increase it, as manufacturers go for a very safe number making sure the front will locked up before the rear even when we are using crappy tires on the front. so for race / track where tires will be properly maintained they aim to bring the bias closer between front and rear while still keeping the front locking first.
let me hear what you think, as this is not what " I know ", is just what I've understood from some reading I've done and I can be very well misinformed or have misunderstood the data, so some of you should support / contradict what I'm saying so we can all move in the right direction.
post Oct 9, 2012 - 9:58 PM
hes a hater, watch out....
post Oct 13, 2012 - 4:05 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
This went a little off topic lol I guess I'll ask my mechanic for advice
post Oct 14, 2012 - 2:38 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (DIONYZUZ @ Oct 13, 2012 - 5:05 PM) *
If you're going to give it to your sister, then just stay with the stock calipers. They are fine and do a good job with braking as it is.
I just have the MR2 calipers because 1) they bolt right onto the caliper bracket and 2) I like to do autocross and etc so it will help distribute the braking more evenly between the front and rear.
There's no point in doing more than rotors and pads because those will be good enough for regular driving.
post Oct 14, 2012 - 10:47 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
QUOTE (mkernz22 @ Oct 14, 2012 - 2:38 PM) *
Ok so the pins and other components along the brake system should be fine?
post Oct 23, 2012 - 6:44 PM
trdproven
Joined Aug 2, '05
From Guam
you should get new calipers if you could they are dirt cheap anyway at rockauto. you should also get brand new line gaskets and buy yourself some grease for the shims.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: June 14th, 2026 - 5:36 AM
