> coilover cut my axle boot. how to fix it?
post Oct 22, 2012 - 4:21 PM
diegohiga
Joined May 4, '09
From coral springs florida US
i didnt realized that the coils was rubbing my axle boot and it cut it. it only happened on the passenger side.
can i grind the coil or i it will get damaged? rasing the car i the last option.
Replies (1 - 8)
post Oct 22, 2012 - 4:49 PM
Sadly....raise the car
post Oct 22, 2012 - 4:58 PM
cheela
Joined Feb 2, '07
From Berlin, WI
post Oct 22, 2012 - 6:29 PM
diegohiga
Joined May 4, '09
ill see what can i do..
This post has been edited by diegohiga: Oct 22, 2012 - 6:56 PM
post Oct 22, 2012 - 9:01 PM
Shorter shock cartridge. BC can special order their 'extreme low' kit, I think they have a 6GC application. It's got shorter cartridges, you can slam so low you'll bind ball joints and ruin axles faster than you can replace them.
post Oct 23, 2012 - 2:44 AM
Syaoran
Joined Jan 4, '12
From US
Maybe put some kind of rubber insulator around the sleeve so if they rub the sleeve doesn't slash through the boot when at speed.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Oct 23, 2012 - 12:05 PM
celica74
Joined Feb 8, '10
From North Carolina
When i set my coils i made sure i had a fingers gap for this reason. And i still rub on everything. Cant imagine that ride.
post Oct 23, 2012 - 8:09 PM
trdproven
Joined Aug 2, '05
From Guam
typically you should have a 1" gap between the bottom of the coilover, and the boot, when jacked up, to know you have clearance when the car is back on the ground it would get a lil closer.
This post has been edited by trdproven: Oct 23, 2012 - 8:10 PM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Oct 24, 2012 - 9:08 AM
celica74
Joined Feb 8, '10
From North Carolina
Had mine on the rack and made sure nothing was hitting. If you look at pictures of my car and then his theres a noticeable(understatement) drop difference.
Lo-Fi Version Time is now: June 12th, 2026 - 7:09 AM
