> Modifield engine from autocraft on ebay, S O S is reliable the autocratft
post Nov 15, 2012 - 4:17 PM
GT4
Joined Sep 2, '11
From cyprus
Hello guys i need your opinion i found on ebay one company who make modifield engines for toyota celica st205
the web is this http://www.ebay.co.uk/itm/FULL-RACE-3SGTE-...=item3a7b90a22e
does any one order from this guy ? is reliable ? should i trust him ??
please help
Replies (1 - 9)
post Nov 15, 2012 - 7:19 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
You might want to comfirm, But I'm pretty sure you need to supply the engine. The cost that they're showing on that website is simply for their rebuild, not the cost of an engine.
post Nov 15, 2012 - 11:38 PM
Syaoran
Joined Jan 4, '12
From US
Sleeving the engine and then putting in wiseco pistons and eagle rods...
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Nov 19, 2012 - 12:13 AM
why sleeve the engine? its an iron block. you can make 500HP without sleeves
post Nov 19, 2012 - 11:16 AM
Syaoran
Joined Jan 4, '12
From US
They're Honda engine builders... apparently they sleeve everything and anything lol.
post Nov 19, 2012 - 2:03 PM
GT4
Joined Sep 2, '11
From cyprus
hmmm guys uf i change my pistons only can i go to 400 hp ? coz some one told the 3sgte rods can go up too 600-700hp is thats true ??
post Nov 19, 2012 - 8:31 PM
QUOTE (Smaay @ Nov 18, 2012 - 11:13 PM) *
I've read more than one place that the bore spacing between 2 and 3 is pretty small and as such at high power levels the coolant between them in the water jacket can boil and cause hot spots that can crack the cylinders. The coolant flash boils, the cylinder gets really hot in that one spot, then the coolant condenses and quenches it suddenly. After many cycles it can crack. Sleeves are made from steel, not iron, and are much more resistant to this. Probably just insurance on their part.
This post has been edited by Bitter: Nov 19, 2012 - 8:33 PM
post Dec 30, 2012 - 12:17 AM
mikal
Joined Dec 30, '12
From area88
QUOTE (GT4 @ Nov 15, 2012 - 4:17 PM) *
please help
they send a lot of engines to greece,cyprus and poland, my engine is with them now, it should be done in January ill let you know what happens
QUOTE (Smaay @ Nov 19, 2012 - 12:13 AM) *
ive all ready tried that, the sleeves cracked and data log showed no knock or lean condition when it happened, car made 440whp and cracked the block
post Dec 30, 2012 - 1:38 PM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (Syaoran @ Nov 19, 2012 - 11:16 AM) *
If they know the 3SGTE engines then they wouldnt sleeve it.
This post has been edited by yellowchinaman: Dec 30, 2012 - 1:48 PM
post Dec 30, 2012 - 3:29 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
Buddy of mine down here cracked the bore so he ended up sleeving and cementing the coolant passage...
currently running low 10s in a Caldina
Lo-Fi Version Time is now: August 31st, 2026 - 4:22 AM
