Dec 16, 2012 - 2:14 PM
![]() Enthusiast ![]() ![]() ![]() Joined Jun 2, '10 From Davenport, Florida Currently Offline Reputation: 0 (0%) |
ok the noise its making sounds like truck tires road noise, loud consistent with vehicle movement, low pitch at slow speeds higher pitch at higher speeds. it does not however vary with engine or transmission rpms or steering directions left or right much like tire noise. the noise appeared indiscriminately one second quiet next second noisy while driving. the noise appears to be coming from the passenger side or center of the vehicle cant pinpoint while driving
here's what i have checked so far changed tires and the noise remains here's vehicle history regarding driveline 11/12 drivers side wheel bearing replaced 11/12 front rotors and pads placed 8/12 front end alignment 8/12 front tires replaced 7/12 passenger side wheel bearing replaced 12/11 cv axles replaced friend of mine suggested its the bearing that supports the passenger side cv axle extension to the transmission but for the life of me i cant find what that bearing is called to price out a replacement any thoughts or if you know this noise please reply -------------------- ![]() |
Dec 16, 2012 - 7:10 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 4, '12 From US Currently Offline Reputation: 6 (100%) |
I think you are looking for the axle carrier bearing.
-------------------- 1993 Celica GT Coupe - sold
1994 Celica GT Liftback |
Jan 7, 2013 - 6:24 PM
problem figured out.... metal shavings in the gear oil
Jan 7, 2013 - 8:30 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 23, '12 From Warrior, AL Currently Offline Reputation: 0 (0%) |
I find it odd that it'd make noise in all gears though. Just drive it until you notice a lack in performance or it completely ****s the bed.
Jan 7, 2013 - 10:38 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 29, '11 From Haltom City, Texas Currently Offline Reputation: 1 (100%) |
A small amount of metal can be expected from normal wear. Drain it and put new fluid in.
I would suspect the carrier bearing(on the pass. cv axle) or wheel bearing. Replacement parts are 100x more likely to fail than factory parts in my experience, so its always best to suspect repair work first and Toyota's work second. You could place the front wheels on jackstands and rotate the wheels by hand to see if you can hear or feel the problem. You can also very carefully place the vehicle in drive/gear with the engine running while it is still on the jackstands in order to replicate the noise. But I cant in good faith suggest crawling under the vehicle with the engine while its in gear. Good luck and be safe. This post has been edited by Special_Edy: Jan 7, 2013 - 10:39 PM |
Jan 10, 2013 - 7:38 AM
replaced the carrier bearing and the noise persisted, took it to a shop and they put it on the lift and ran it with the wheels free, the noise is coming from around the differential. it was more then a small amount of metal shavings that you would get from the occasional missed shift. mechanic thinks the metal shavings may have damaged the output shaft bearings and causing the noise however he was uncertain of the condition of the rest of the transmission with the amount of metal shavings in the oil he believes the root of the problem isn't the output shaft bearings but rather something internal that caused them to go bad. I found a transmission cheap enough so i'm just gonna replace the whole thing and be done with the problem.
Jan 26, 2013 - 11:29 PM
transmission and new clutch are in all is good again no more noises
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:14 AM |
