> Projectors PROBLEM
post Jan 23, 2013 - 1:54 PM
tto010
Joined Jul 6, '12
From NORWAY
The Chrome on my projectors chrome ring thing have come off, any way to fix it???
It just disappeared when i touched it.... (doing the LHD convertion)
Thought about 1/16 model build kit car's chrome paint.... but dont want to ruin anything...
Last option will be just paint it black... will that work/be cool? (anyone done it?)
Pic: http://s753.beta.photobucket.com/user/tto0...?sort=3&o=0
Replies (1 - 18)
post Jan 23, 2013 - 2:02 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I believe there was a member who just fixed something similar to like these.
I think it was diegohiga, and IIRC he just used a chrome rattlecan paint.
My Celica!
post Jan 23, 2013 - 2:50 PM
diegohiga
Joined May 4, '09
From coral springs florida US
yes i did but the the orinal one is more shiny and you can see your reflection as a mirror. you wont achieve the same results with a rattle can.
even body shops dont have chrome paint. I really have no idea how toyota and other companies get that shiny chrome looking.
this is mine.. not bad and is the closet paint to chrome.
post Jan 23, 2013 - 3:06 PM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
QUOTE (diegohiga @ Jan 23, 2013 - 12:50 PM) *
Its a special super-thin plastic sheet that is heated up and vacuum formed onto the projector shroud.
This post has been edited by smkr3w: Jan 23, 2013 - 3:15 PM
post Jan 23, 2013 - 3:19 PM
tto010
Joined Jul 6, '12
From NORWAY
found something:
http://www.bare-metal.com/bare-metal-foil.html
that works?
Or this stuff: http://txd-china.en.made-in-china.com/prod...ilver-Foil.html
This post has been edited by tto010: Jan 23, 2013 - 3:22 PM
post Jan 23, 2013 - 3:24 PM
smkr3w
Joined Nov 29, '10
QUOTE (tto010 @ Jan 23, 2013 - 1:19 PM) *
that's for model cars and adheres to metal.
you could dry using Mirror Chrome Vinyl? HERE
post Jan 23, 2013 - 3:46 PM
tto010
Joined Jul 6, '12
From NORWAY
QUOTE (smkr3w @ Jan 23, 2013 - 4:24 PM) *
Model cars is in plastic....
But ill try use chrome vinyl. only down is that since i live in Norway i will not get it before some time next month. Realy sucks... so think i will try to find some local stores that sells it.
post Jan 23, 2013 - 3:48 PM
Box
Joined Feb 23, '12
From Warrior, AL
Y NO KRYLON? http://www.krylon.com/products/premium_metallic/
2001 Miata LS 5-speed
post Jan 23, 2013 - 4:39 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Why dont you try sanding the chrome/metallic paint lightly with 2000-2500 grit sandpaper and then buffing and finally polishing. A brand new coat of paint on your car isnt super glossy either, its dull till you buff it.
post Jan 23, 2013 - 5:59 PM
Syaoran
Joined Jan 4, '12
From US
Chrome on the projectors and other stuff like them is done by electro-plating I believe.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Jan 23, 2013 - 9:28 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Syaoran @ Jan 23, 2013 - 4:59 PM) *
When the material is metal that's the case. On plastic it's some kind of vacuum forming. Plastic can be chrome plated, but it takes lots of steps and there'd be evidence of the base metals on the projectors. The Krylon metallic chrome should work well.
post Jan 24, 2013 - 4:10 AM
wolfie308
Joined Nov 21, '05
From England
Close - it's actually done by vaporised metal in a vacuum chamber being deposited onto the electrically charged piece.
Box, you're right, there's several steps, see here for the process......
http://www.vmclimited.co.uk/metalising.php
Has your car ever been on T.V? Mine was used in the opening sequences here - note the clear turns and front LED's
http://videos.streetfire.net/video/Wheeler...11-9c0f00a0b820
post Jan 24, 2013 - 9:50 AM
diegohiga
Joined May 4, '09
QUOTE (smkr3w @ Jan 23, 2013 - 3:24 PM) *
post Jan 24, 2013 - 3:40 PM
tto010
Joined Jul 6, '12
From NORWAY
but this got me thinking...
What if i paint them black?
Isnt the light spreaded by the projector lens?
and ill just mask up the park light bit, and just keep that chrome since that bit is intact.
and if it is crap, just paint it with chrome paint after.
But that involves ruining 1 side of perfectly good reflector... (will ofc not try here first.... laugh.gif )
This post has been edited by tto010: Jan 24, 2013 - 3:48 PM
post Jan 24, 2013 - 3:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
Go for gloss black, should look good.
post Jan 24, 2013 - 8:23 PM
richee3
Joined Jun 29, '08
From Denver
You can paint the projectors. I've seen it done several times. The only one that immediately comes to mind is Culpable04.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jan 25, 2013 - 4:48 AM
smkr3w
Joined Nov 29, '10
QUOTE (diegohiga @ Jan 24, 2013 - 7:50 AM) *
well technically you add some heat and it'll be as pliable as you want it to be...
but I meant just the leading portion of the shroud where his chrome is coming off (pretty falt- would need trimming)
I would say paint.. i like the look painted JDM's
post Jan 25, 2013 - 8:54 AM
Special_Edy
Joined Oct 29, '11
Like I said if you paint it (specifically rattlecan chrome paint) you should try buffing the paint then polishing, you can turn anything into a mirror surface. It may or may not work with various types of paint but it should work on some.
post Jan 25, 2013 - 2:29 PM
richee3
Joined Jun 29, '08
From Denver
Here are some pictures of Culp's car.
Not sure whose this is.
1998 Celica GT-
BEAMS Swapped.
Lo-Fi Version Time is now: September 12th, 2026 - 3:09 AM
