Jan 26, 2013 - 4:32 AM
Guys I have an UAFC for sale. This requires you to cut the signal from your MAF/MAP sensor that sends the voltage signal to the ECU, routes it to the unit and then send it back into the cut wire that feeds into the ECU side. Its 12V powered, supports RPM pickup and is USB. Comes with a free data logging software
You can find out more at http://www.14point7.com/. And download the user instruction manual to find out more. It has 3 different switch over map tables at the push of a button and you can even maintain your stock ECU settings with it wired up. Great if you can't afford a high dollar piggyback, or if you want to run E85. It has a 12X12 table for your fuel settings. I have never installed it and its still fairly new in the box. Asking $100 shipped. |
| Lo-Fi Version | Time is now: July 31st, 2026 - 10:15 AM |
