> Staggerred Setup, XXR 521 18x10
post Feb 15, 2013 - 4:45 AM
RMG6gc95
Joined Jan 10, '13
Hey guys I'm trying to figure out if a staggerred setup with XXR 521 will fit my 1995 celica? I'm wanting to buy the 18x10! I dont really know much about staggerred setups or offsets!
Will I need camber on rear? And wat tire size would be good for those wheels?
Really would appreciate you'lls replys!
Thanks!
Replies (1 - 5)
post Feb 15, 2013 - 5:17 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
10" up front will be way to big to fit, and probably even so in the rear. From what i read the 18x10 have a +25 offset, which is massive.
Depending on how flush, poke etc you want, you'll be better off going the 8.5" wide. Depending on what color you want, has an offset of 35, or 25.
+25 would look real nice, but would be pretty poked up front.
Also depends if your staggered by width, or offset etc
post Feb 15, 2013 - 10:19 AM
Malek
Joined Jan 26, '09
From Los Angeles
Flush yo wheels
post Feb 15, 2013 - 2:32 PM
RMG6gc95
Joined Jan 10, '13
QUOTE (Timmyface @ Feb 15, 2013 - 6:17 AM) *
Okay so as for being staggerred then wat wheel width would fit right on the rear and the front should be smaller so wat width for the Front? And offsets?
post Feb 15, 2013 - 4:09 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
The thread that malek posted is pretty easy to read. There's no reason to really want to go staggered in width, because we are FWD. so you'll probably want to look for 8.5" +30 up front +10 rear. Or close enough. Depends again if you want flush, poke etc. depending how low you are, and suspension you could probably get away with 9" +30 and add a small spacer.
Pretty much you'd want the rear to be 13mm less offset, or an inch smaller in width.
post Feb 16, 2013 - 1:42 AM
RMG6gc95
Joined Jan 10, '13
Lo-Fi Version Time is now: September 3rd, 2026 - 5:38 AM
