Feb 24, 2013 - 1:30 PM
Enthusiast Joined Feb 24, '13 From usa Currently Offline Reputation: 0 (0%) |
I need help with beams swap! what diameter downpipe do is needed, will the intake air filter system swap over. will the tubes from the radiator swap out as well? any help would be much appreciated.
Feb 24, 2013 - 2:50 PM
from what it seems you are jumping the gun without actually having any idea what the swap may entail. I suggest you read the threads that detail this swap. to answer your questions
every clip or engine you buy should come with the intake air filter and the exhaust manifold and b- pipe. otherwise dont buy the engine, or youll be screwed. a missing part will give you headaches, and will be hard to find. -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Feb 24, 2013 - 3:50 PM
from what it seems you are jumping the gun without actually having any idea what the swap may entail. I suggest you read the threads that detail this swap. to answer your questions every clip or engine you buy should come with the intake air filter and the exhaust manifold and b- pipe. otherwise dont buy the engine, or youll be screwed. a missing part will give you headaches, and will be hard to find. I'm talking about the air intake I have an aem cold air intake would that fit and it doesn't come with the downpipe to flexpipe I need to know what is in diameter 2inch or 2.5inch |
Feb 24, 2013 - 6:26 PM
I'm talking about the air intake I have an aem cold air intake would that fit and it doesn't come with the downpipe to flexpipe I need to know what is in diameter 2inch or 2.5inch He knows what you are asking about, and he gave the best answer he could possibly have given. The BEAMS swap is as easy as a swap gets and there's plenty of information on the forums about it, but if you're asking a question as simple as intake compatibility then you'll have serious issues with the swap. I'm not trying to be a jerk, but seriously, the intake is pretty common information on the BEAMS. To answer your question- no, your AEM intake will be scrap when the 5S comes out. 2.5" piping for the B pipe. An exhaust shop can fab up a B pipe for you, but getting the factory B pipe would have been easier and the BEAMS will not even start with a proper intake, and the factory intake is by far the best intake for it. Again, not trying to be a jerk. I know it sounds like I am, but without knowing which intake will work, a BEAMS swap will not come together. You'll definitely want to give these threads a few good reads. njccmd2002- "I Swapped 3s-ge Redtop Into '97 Limited Edition Vert." turnip- "Swap: 3sge Beams into 94 GT" hurley97/Batman722- "New Addition to Our Family" erahman85- "One acronym... BEAMS" This post has been edited by richee3: Feb 24, 2013 - 6:39 PM -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Feb 24, 2013 - 10:44 PM
Your arm intake will make a Great Wall decoration, sorry bro! It's all in those threads
Feb 25, 2013 - 9:32 PM
Mar 3, 2013 - 12:16 AM
Your arm intake will make a Great Wall decoration, sorry bro! It's all in those threads that's cool I was gonna do new stuff anyhow but where can I find a b-pipe or will I have to Fab one I've bought the downpipe from the UK not bad in price now I need intake pipe an air box any help where to get one or a good short ram |
Mar 3, 2013 - 10:15 AM
The MAF is the end-all and be-all on the BEAMS. It's incredibly finicky. It demands that the intake pipe be exactly 71 mm, otherwise it runs pig rich and kills power. That limits your options to the factory intake, which has proven dyno gains over the other intakes, available from Vincent_Doggy. You can also get a SARD intake, the only aftermarket intake specifically designed for the BEAMS, available here. Costs about the same as the factory intake, not as much power. Njccmd has an HKS MAF adapter for sale, you would just need to buy an air filter for it. Or, you can go with the cheapest option, a 97-01 Camry SRI, but this will give the least power. It's not a difference of 50 hp, realistically 10-15 at most. I've had the Camry intake, SARD intake, and OEM. I will say that my BEAMS runs far smoother and has slightly better throttle response with the OEM intake. It's worth the extra money to some, but not others.
Mar 3, 2013 - 11:45 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
You might be able to use a air box for the 97-01 Camry too
The maf mounts into it an it might even match up to the bottom of the stock airbox in the celica or with alil work you could use the whole stock intake from a 97+ 1mz They use the same maf so with alil effort it should work I haven't done a Beams swap but on the intake side of things the beams an 1mz have a lot in common -------------------- 95 gt coupe, v6 swap weekend toy
99 gt hatch beams swapped wife's 94 st hatch my daily driver http://www.6gc.net/forums/index.php?showtopic=82235 n |
Mar 3, 2013 - 11:46 AM
The MAF is the end-all and be-all on the BEAMS. It's incredibly finicky. It demands that the intake pipe be exactly 71 mm, otherwise it runs pig rich and kills power. That limits your options to the factory intake, which has proven dyno gains over the other intakes, available from Vincent_Doggy. You can also get a SARD intake, the only aftermarket intake specifically designed for the BEAMS, available here. Costs about the same as the factory intake, not as much power. Njccmd has an HKS MAF adapter for sale, you would just need to buy an air filter for it. Or, you can go with the cheapest option, a 97-01 Camry SRI, but this will give the least power. It's not a difference of 50 hp, realistically 10-15 at most. I've had the Camry intake, SARD intake, and OEM. I will say that my BEAMS runs far smoother and has slightly better throttle response with the OEM intake. It's worth the extra money to some, but not others. that my problem can't one anywhere! you have the link? |
Mar 3, 2013 - 12:11 PM
The MAF is the end-all and be-all on the BEAMS. It's incredibly finicky. It demands that the intake pipe be exactly 71 mm, otherwise it runs pig rich and kills power. That limits your options to the factory intake, which has proven dyno gains over the other intakes, available from Vincent_Doggy. You can also get a SARD intake, the only aftermarket intake specifically designed for the BEAMS, available here. Costs about the same as the factory intake, not as much power. Njccmd has an HKS MAF adapter for sale, you would just need to buy an air filter for it. Or, you can go with the cheapest option, a 97-01 Camry SRI, but this will give the least power. It's not a difference of 50 hp, realistically 10-15 at most. I've had the Camry intake, SARD intake, and OEM. I will say that my BEAMS runs far smoother and has slightly better throttle response with the OEM intake. It's worth the extra money to some, but not others. that my problem can't one anywhere! you have the link? thanks checked the link and messaged njccmd for mad adapter I'm just excited to rip the pos Honda boys apart |
Mar 3, 2013 - 1:27 PM
You might be able to use a air box for the 97-01 Camry too The maf mounts into it an it might even match up to the bottom of the stock airbox in the celica or with alil work you could use the whole stock intake from a 97+ 1mz They use the same maf so with alil effort it should work I haven't done a Beams swap but on the intake side of things the beams an 1mz have a lot in common The Camry intake doesn't fit in a Celica. I can't remember who but somebody tried it and said it didn't work. -------------------- "Employ your time in improving yourself by other men's writings, so that you shall gain easily what others labored hard for." -Socrates. Even Socrates told us to use the search button!
Mar 3, 2013 - 5:37 PM
Ahh.....well guess that won't work.
Mar 4, 2013 - 2:08 PM
Mar 6, 2013 - 2:14 PM
i wasted my money with the oem camry intake.... it makes a great dust collector in my garage.
Mar 6, 2013 - 10:59 PM
Mar 8, 2013 - 12:36 PM
for reference camry intake...
Apr 11, 2013 - 12:40 PM
Need a pinout diagram for beams swap any help will be greatly appreciate...
Apr 11, 2013 - 12:45 PM
What are you stuck on? You don't need the entire diagram to swap the BEAMS, it would only end up confusing you worse and making everything way more complicated than it needs to be. There are only a few wires to repin. If you still need the pin out diagram, there's one over on mr2.com in their BEAMS Owners Group section.
Apr 11, 2013 - 12:46 PM
You might be able to use a air box for the 97-01 Camry too The maf mounts into it an it might even match up to the bottom of the stock airbox in the celica or with alil work you could use the whole stock intake from a 97+ 1mz They use the same maf so with alil effort it should work I haven't done a Beams swap but on the intake side of things the beams an 1mz have a lot in common The Camry intake doesn't fit in a Celica. I can't remember who but somebody tried it and said it didn't work. im using a camry intake, isnt the throttle body on the Beams in the same place as a 5S? is the MAF the same as the 1MZ MAF? -------------------- 2001 Celica GT-S Turbo
| Lo-Fi Version | Time is now: August 29th, 2026 - 6:23 PM |
