> 7afe clutch, quick question
post Mar 17, 2013 - 7:42 PM
kormysh8
Joined Nov 14, '09
From Saskatoon
I need to replace the clutch on my 94 st. I will be going with exedy stage 1.
part number is 16800 for the stage 1, The description on the exedy website states the disk size is 215mm.
Part number is KTY03 and KTY18 for the standard OE replacement, and the description on both of those state the disk size is 210mm.
SoooOOoo... which one should i choose? Don't i have to have the same size as my flywheel? (which i don't know)
Thanks
Replies (1 - 2)
post Mar 17, 2013 - 10:58 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'd just go with an OEM replacement, unless you've done a turbo setup or what have you. Save some money, save some peace of mind.
2001 Miata LS 5-speed
post Mar 17, 2013 - 11:01 PM
yeah id get an OEM clutch, it will probably be cheaper too. if you are looking for a slight upgrade, get an OEM clutch for a 2000 celica GTS.
Lo-Fi Version Time is now: August 26th, 2026 - 11:19 AM
