> 17x8 +47 =not a good idea
post Apr 10, 2013 - 7:33 PM
billkisme
Joined Apr 3, '13
From gettysburg, pa
The girlfriend bought a set of drag dr38s in 17x8+47 with 225/45/17 tires and we went to mount the read rims and the rim is hitting the strut. So I just bought a set of 25mm spacers for the rear.
So the spacers should be here in a few days. What else would you guys have done?
Replies (1 - 8)
post Apr 10, 2013 - 7:52 PM
whatthe
Joined Aug 13, '08
From Australia
Yep spacers will solve the issue.
I would of also had a stern word with the girlfriend. Sure surprises are nice. But she needs to understand the offset!
post Apr 10, 2013 - 8:08 PM
billkisme
Joined Apr 3, '13
From gettysburg, pa
QUOTE (whatthe @ Apr 10, 2013 - 7:52 PM) *
Hhaha. I knew about the rims and we were going to go with +35 offset but the company didn't have them in stock but they had the +47 and I really didn't think 12mm would make that much of a difference and me not know much about the celica cause I'm more of a Honda guy. But I'm running 25mm spacers all around on my civic. So that's why I went with them.
Now I didn't get spacers for the front cause there's about a half inch gap between the rim and strut so I thought that would be OK.
post Apr 10, 2013 - 9:44 PM
block
Joined Jul 27, '06
From Soda
I really do not understand why people bother with such high offsets. Our stock offset is +35 and should stick with wheels @ that offset or lower. GL and hope everything works out. And post pictures!
post Apr 10, 2013 - 9:51 PM
mkernz22
Joined May 10, '10
From MA
Is that a 1/2" when on the ground or in the air? cause if it's while in the air then it may rub once you put it back down.
post Apr 10, 2013 - 10:01 PM
billkisme
Joined Apr 3, '13
From gettysburg, pa
QUOTE (mkernz22 @ Apr 10, 2013 - 9:51 PM) *
Your totally right. It was in the air when test fitted . Once I get the rear spacers and fit them and try the fronts out and drive around and if the fronts rub I'll get some 5mm spacers and go from there.
post Apr 10, 2013 - 10:50 PM
Malek
Joined Jan 26, '09
From Los Angeles
Weird..
I just mounted 17x8 +48 on my celica with stock suspension..nothing rubs cwm13.gif
They're stamped and I even measured the offset a few weeks ago..
post Apr 11, 2013 - 3:26 AM
Nihil
Joined Jul 17, '12
From Slovenia
I use this tire/wheel comparer (link) where you can see all the dimensions and differences between two different sets of wheels. You can also see what is your speedometer reading mistake going to be on a taller set of wheels than stock dimensions. Useful thing.
post Apr 11, 2013 - 9:08 AM
Red123
Joined Oct 25, '11
From Tbilisi
QUOTE (Malek @ Apr 10, 2013 - 10:50 PM) *
Weird..
I think he has a ST205.
Lo-Fi Version Time is now: July 29th, 2026 - 7:09 PM
